Marantz MM9000 4-ohm stable?
Mazeroth
Looking to run one of these to some Polk LSis but want to make sure it's 4-ohm stable before I purchase one. If it is, any idea how many watts it makes at 4-ohms? THANKS! I was also considering making a dual-fan using heavy duty computer case fans to cool the amp if I will be running it at 4-ohms. Think this will help? THANKS!
Post edited by Mazeroth on
I've never had any experience with the MM9000 but I have read that it's more comparable to an amp section found in a receiver.
Will it work in 4 ohms? Probably. Will it sound good at 4 ohms? Try it and see.
If you looking for a budget five channel amp to run LSi's try a Rotel RMB-1075 or even it's predecessor the RB-985, which can be had used for around $500.
-Jason -
These are the best specs I could find:
FEATURES
150 watts (into 8 ohms) x 5 channel power output
Oversized high-capacity toroidal transformer
Premium quality internal components
THX Ultra® certified
SPECIFICATIONS
Continuous power output (RMS) into 8 ohms
(<.03% THD, 20 Hz - 20 kHz)
Front left and right channels 150 + 150 W
Center channel 150 W
Surround channels 150 + 150 W
Input sensitivity 100 mV/1 W Output
Input impedance 20 k½
Frequency response (-1 dB) 5 Hz to 100 kHz
Signal to noise ratio 95 dB
GENERAL
Power requirements 120 V, 60 Hz, 400 W
Dimensions W/H/D 17 5/16 x 6 5/16 x 7 4/5
Weight 44.1 lbs. 20 kg.
It's got some heft, a good sign. But the power draw concerns me a bit. Seems a bit light for a 150 x 5 watt amp...
See if you can get a 4 -ohm rating and a current capacity. If the specs are around 225 and 40 amperes per channel respectively, or better, then I would say it's stable.
As for the fans... if you have to add them for 4 ohm operation, I'd say you picked the wrong amp...More later,
Tour...
Vox Copuli
