Need recommendations on Center and Rear speakers
I recently purchased 2 RTI8 Floor standing speakers with a PSW505 subwoofer. I would like to connect these to a Yamaha RX-V671. I am however overwhelmed with the choice of surround (rear) and center speakers.
1. For the RTI8s, would it make a difference if I go with CSI3 or CSiA4? Would you recommend any others?
2. For Rear would OWM3 be sufficient or would something like RTI4 or RTI A1 be recommended?
Thanks!
Thanks!
Post edited by svaranasy on
For sure the CSiA4 for the center and maybe the FXiA4 or the RTiA1 for surround.
Welcome to the clubSource: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
Thanks!
I would go with the rti4 for surrounds, that is the speaker from the same model line and generation as your rti8 and would be a better and a CHEAPER match
I think they are $149 a pair at polkdirect on ebay.Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
CSiA4 is later version of CSi3....I would get CSi3 since it will match RTi8 that you already have....
and the changes were mostly cosmetic...Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
