Carver AV-405 (409 ?) Worth Having?
skrol
skrol Posts: 3,452
edited March 2012 in Electronics
I am looking at what I believe is a Carver AV-405. The seller said AV-409 but I can't find any such thing. It is a 5-channel amp but he says that he had a tech disable the 2 rears in order to provide better 3-channel performance. I can see where this could make sense but is it a good idea?
I am interested in the amp mainly for 2-ch and I know that there are better Carvers and Adcoms out there but the price seems good.
Anyone know anything about the AV-405? Could this be a good deal or should I save my nickles and dimes?
Stan
Stan
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
    EndersShadow Posts: 17,704
    edited March 2012
    Depends on what he's asking for it and if he truly had a tech disable the rear 2 channels, or if they stopped working due to bad electronics.
    Here is some info on the 405: http://www.carveraudio.com/index.php/amplifiers/av-405
    Here is the manual (from a different carver site): http://thecarversite.com/shell2.htm
    This forum might be a good place to ask some questions: http://www.carveraudio.com/index.php/forum
  • gdb
    gdb Posts: 6,012
    edited March 2012
    A lot of the multichannel Carver amps had what was termed "power steering" which sent unused power to channels that required it. Carver factoids are plentiful at: http://thecarversite.com/yetanotherforum/default.aspx?g=forum
    The resident techs there can probably answer your question.:wink:
  • izafar
    izafar Posts: 819
    edited March 2012
    I used to own AV 405, good starter amp if you can get it around $150.
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • skrol
    skrol Posts: 3,452
    edited March 2012
    Thanks for the info. I didn't really see anything on the Carver Site forums for the amp. I may have to join to post the questions.
    The guy wants $135 but with only 3-channels. Apparently the board for the rear channels has been removed and not available.
    He also has a Bravo Audio 6DJ8/6N1 headphone amp that looks interesting.
    Stan
    Main 2ch:
    HT:
    Other stuff:
