Whats your opinion on this situation
Jed85
Jed85 Posts: 7
edited March 2012 in Car Audio & Electronics
I have 2 kicker cvr's 12"s and 2 12"s Rockford p3's pushed by two 1200 watt mono amps one kicker and one Rockford with two car batteries and a jvc dash should be crazy and install all 4 or just the two what would you do cuz I have nothing to lose if they sound bad I know I will have to tune each amp separately what should I do help
Post edited by Jed85 on
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited March 2012
    maybe make ur post a little more clear
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • ocharlas
    ocharlas Posts: 61
    edited March 2012
    Those subs are pretty beefy. I can't imagine what kind of vehicle 2 12" P3s wouldn't be enough for. I had a much less powerful 2 12" setup in a 15 passenger van and it was more bass than I knew what to do with. I'd just go with whichever 2 you like best (matching obviously)
  • Jed85
    Jed85 Posts: 7
    edited March 2012
    My car is a 95 Cadillac sedan deville and all the speakers fill the trunk of my car except for the sides and a little in the front also I have made a little port threw the back seats arm rest so my trunk wouldn't be fully enclosed and if I were to choose one make of subs it would be the p3's just because they sound clear unlike the kickers are just for the deep bass
  • pentoncm
    pentoncm Posts: 379
    edited March 2012
    Are you saying that you have little speakers in the front? That would be something to consider upgrading in order to get your sub to sound better - integration.
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
