Which LSi to go with?
Looking to get some Polk LSi speakers due to getting a discount on them where I work. I will be using an HK AVR 230 as a pre/pro and running a Marantz MM9000 (150x5 @ 8 ohms) on the Polks. What I want to know is should I go with LSi9s up front or go with the full-range towers, the LSi15s? In the specs it seems the 15s would handle midrange a little better, due to having all the bass given to the 8" driver while the dual 5.25" pick up 150hz and above. The LSi9s don't have a HPF (high pass filter) and one handles all low range up to 200hz and the other takes all low-mids up to 2.4khz.
Also if I get the 15s I'm thinking of bi-amping them and running the last channel to the center. The way my townhouse is setup it's going to be VERY hard to get rears to work so I was just thinking of doing a 3.1 setup. I listen to music 80% of the time anyhow and it reall wouldn't hurt me to not have rears.
***This taken off Polks site to maybe help you guys understand the crossovers better***
POLK LSi15s:
Driver 1: HPF at 150Hz 6dB/oct, LPF at 800Hz 12dB/oct.
Driver 2: HPF at 150Hz 6dB/oct, LPF at 2.4kHz 12dB/oct.
Tweeter: HPF 2.4kHz 18dB/oct.
Crossover(subwoofer) LPF at 150Hz 12dB/oct.
POLK LSi9s:
Driver 1: LPF at 200Hz 12dB/oct.
Driver 2: LPF at 2.4kHz, 12 dB/oct.
Tweeter: HPF at 2.4kHz 18dB/oct.
ANY input is greatly appreciated!
POLK LSi15s:
POLK LSi9s:
Post edited by Mazeroth on
3.1 doesnt seem like a good idea to me. If you have already bought the 230 then I would go 5.1, otherwise what's the point? If you can really only fit the fronts in then go 2 channel and sell or dont buy the 230 and buy a better 2 channel preamp. Biamping is fine, just leave the 5th channel of the marantz unused and dont buy a center, save up for when you have space for 5.1. go for 2.1 or 5.1, 3.1 doesnt make any sense.
We will be building a house in 2 years and I would like to have a receiver that's 5.1 (actually it's 6.1 with 7.1 outputs) for another application, maybe even for my computer as I computer game a ton. Also I may be able to pick up or I might even just buy (2) Polk LSi9s with my purchase and not use them until I do have room for them. I really don't see myself buying a new speaker setup for the next 5 years and that may be the way to go. Also while watching a movie how often do you even notice the rears? I don't notice mine very often and when I do it's only brief and usually not important.
Imo, the 9 is the better speaker of the two. I don't feel the 8" woof in the 15 is 'up to speed' with the rest of the drivers.
Close, but not quite there.
Cheers,
RussCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
