4 SVS PC ULTRA 13's
rubin
rubin Posts: 565
Check it out !!!
Post edited by rubin on
  • grimmace19
    grimmace19 Posts: 1,429
    edited March 2012
    Odd how you likely found the brown note and I somehow crapped my pants when I saw that too...
    EndersShadow Posts: 17,704
    edited March 2012
    Holy crap that's gotta be crazy loud
    VR3 Posts: 29,429
    edited March 2012
    Now that is crazy.
    I love it!
    That is like when I had Dual largers in a 10.5x10.5x8 room!!
  • rubin
    rubin Posts: 565
    edited March 2012
    VR3 wrote: »
    Now that is crazy.
    I love it!
    Nice!
  • danz1906
    danz1906 Posts: 5,144
    edited March 2012
    Sweet Subs!!!!
    How do you like the Arcam player?
    I'm have an Arcam DV79, which model do you have?
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • rubin
    rubin Posts: 565
    edited March 2012
    danz1906 wrote: »
    Sweet Subs!!!!
    CD73 strictly redbook and sounds great.
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2012
    Is it loud enough? :wink:
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • rubin
    rubin Posts: 565
    edited March 2012
    More than I need but all that I want :wink:
  • IRLRaceFan
    IRLRaceFan Posts: 172
    edited March 2012
    rubin wrote: »
    Well if you ever get bored with it, I want to be first in line to purchase one...or two
    Enjoy!!
    HT
    Onkyo TX-NR1008 | Magnepan 1.7 | Polk LSiC | Polk VM20 | Polk DSW microPro 2000 | Parasound HCA-2205A | Oppo BDP-93
    2-Ch
    Cary SLP 30 Tube Preamp | Polk LSi7 | Carver M1.5t | Audio-gd Digital Interface | W4S DAC-2 | MAC Mini | Denon DP300f & Pro-Ject Debut III TT's
  • rubin
    rubin Posts: 565
    edited March 2012
    IRLRaceFan wrote: »
    Enjoy!!
    Thanks, I don't think I'll be selling any.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2012
  • Face
    Face Posts: 14,340
    edited March 2012
    Do you have space in the back of your room for a pair? Spreading the 4 out a bit will give you very smooth bass response.
  • rubin
    rubin Posts: 565
    edited March 2012
    Face wrote: »
    No that part is filled with furniture.
  • rubin
    rubin Posts: 565
    edited March 2012
    leroyjr1 wrote: »
    Nice setup!
    Thanks.
  • Sherardp
    Sherardp Posts: 8,038
    edited March 2012
    Wicked!!! Wish I could experience that room playing a wicked video game or Master and Commander on BD.
  • rubin
    rubin Posts: 565
    edited March 2012
    Sherardp wrote: »
    The room has SO MUCH bass and I'm not pushing them at all!
  • danz1906
    edited March 2012
    rubin wrote: »
    What size is your room?
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • rubin
    rubin Posts: 565
    edited March 2012
    danz1906 wrote: »
    24ft x 16ft with doorways and a stairway to other rooms. They have no trouble filling the area "effortless". I got 4 so none would ever be stressed.
  • rubin
    rubin Posts: 565
    edited March 2012
    Well...... all I can say is the system is overkill to the 10th degree. These 4 tubes thump my ears, pound my chest without any effort at all. Not cheap but I love it. Thanks SVS.
  • rubin
    rubin Posts: 565
    edited March 2012
    4 ultras = solid/tight not boom bass. Led Zep houses of the holy never sounded better.
  • thsmith
    thsmith Posts: 6,082
    edited March 2012
    I would have to try one mid way on each wall.
    Have you used any sort room freq measurement tools?
    I believe each one of those have a filter built in to the amp. My pb13 does and I needed it for the massive hump at34hz in my room.
  • rubin
    rubin Posts: 565
    edited March 2012
    Mine have the 750w bash (analog) amps. Tested with a RS analog SPL meter. I run them all wide open-20 db.
    The room is flooded with bass. Phasing is correct as is polarity.
    The room is so saturated, the rat shack meter measurments can't begin to describe the intense bass you hear . Just massive bass, without any strain as one would expect given the quantity of bass provided with 4 units.
  • rubin
    rubin Posts: 565
    edited March 2012
    I prefer co-location for the 6db increase.
  • rubin
    rubin Posts: 565
    edited March 2012
    Correction to post#23. I run them wide open (no ports blocked) which is the 20HZ tuning. Room comp is off.
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited March 2012
    Headroom has a quality all its own. :cool: I wouldn't hesitate to try the 16 Hz mode, too; you certainly have enough sub for it.
    Opposing corner placement is usually fine for that size/shape room. While you could try all four corners per the Harman International white papers, your current placement should provide sufficient modal density to avoid major nulls at the listening position.
    Since the subs are several feet behind the speakers, you'll be dealing with a bit of acoustic latency, unless your pre/pro has provisions for speaker/subwoofer distance settings to correct for this.
    SVS
  • rubin
    rubin Posts: 565
    edited March 2012
    Dr. Spec wrote: »
    Absolutely correct, there is a bit of "bass lag". Nice to hear from you Ed.
