psw505
jmadrox2010
how do i hook up 2 psw505's and how should i place them so they dont sound out of phase?
Post edited by jmadrox2010 on
If you have a sigle sub line out (.1) Then I would run a sub cable over to a stacked set facing the same direction connecting the two with Y splitter.
If you have .2 LFE then you could seperate them but thats a little more difficult in terms of calibration and placement.
PS do you already own 2 PSW505's? If not I would look at getting a single High Quality sub instead. My HSU will smoke 2 PSW505's in my opinion. The advantage of two subs is typically higher db and if their spread out better coverage of room nulls (bass holes). In your case 2 PSW505's still are not going to help get tighter, deeper, cleaner bass. Honestly it will just make the bass louder.
All in my opinion. Some of the smarter guys should chime in.:redface:Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
