Another amp?
TheRealSpinner
TheRealSpinner Posts: 30
edited March 2012 in Vintage Speakers
Wasn't sure where to post this, but it the other speakers I'm using are SDAs, so I'm gonna post it here.
So, I received my GFA555 (original, not mkii) and its at the shop right now, so I haven't heard how it sounds with my SDA-2Bs. I worried that I might not be able to get the bass I'm looking for though, even with the amp and was wondering what my next step might be.
I was thinking, there's another GFA 555 original, and a Parasound 1200 (also original, I believe) for sale, each only $200. Now, do I get one of those and build a sub with a 15" Cerwin Vega that I already have (car speaker, but doesn't matter, right) and build a cabinet that might not actually happen for quite some time, or do I start looking for an equalizer?
-SPINNER-
SDA-2b
Adcom GFA 555
Marantz SR880
JBL CF120
Onkyo TX-SV727
Other Junk
Post edited by TheRealSpinner on
  • drumminman
    drumminman Posts: 3,396
    edited March 2012
    Why don't you hook up the amp and listen to it for a while? And play around with placement of the speakers, which is critical for SDA's.
    heiney9 Posts: 25,506
    edited March 2012
    The 555 will have all the bass you need. If not, then you have either a room issue, placement issue or source issue.
    Before you try to fix something, you should see if it's actually broken. How can you make such a statement when you haven't even heard the gear? Pretty ridiculous.
  • FTGV
    FTGV Posts: 3,650
    edited March 2012
    Why's the Adcom in the shop?
  • TheRealSpinner
    edited March 2012
    Thanks guys, I know I'm being a bit premature here. I get a little impulsive sometimes. I just thought since the other amps seemed like a deal, I might pull the trigger.
    @FTGV, sorry, I should have clarified, the amp is at my shop, (playing music). The amp was delivered there, and I just hooked it up temporarily... because I'm impatient too, and wanted to play with the new toy before I had a chance to bring it home.
    -SPINNER-
    SDA-2b
    Adcom GFA 555
    Marantz SR880
    JBL CF120
    Onkyo TX-SV727
    Other Junk
  • decal
    decal Posts: 3,205
    edited March 2012
    Being impulsive in a hobby like this will cost you big time money.
  • sda2mike
    sda2mike Posts: 3,131
    edited March 2012
    +1 on the adcom's bass abilities with the 2b's...my combo btw
  • TheRealSpinner
    edited March 2012
    Tell me about it.
    -SPINNER-
    SDA-2b
    Adcom GFA 555
    Marantz SR880
    JBL CF120
    Onkyo TX-SV727
    Other Junk
