Grill cover pins
vstarkwell
I'm more then likely gonna cannibalize a pair of Monitor 4.5's that I don't really need and are in rough shape. They are missing the grill covers but the plastic connecting pins are intact. I would really like to repurpose them to one of my 7C's that is missing 2 of them.
What would be the best way to do this?
Monitor 7C's With Tubes
Post edited by vstarkwell on
Dont think u can get them out in one piece. U can try gently twisting and pulling like teeth however you can buy new ones from parts express fairly cheep. I have some for my rta 12's but im sure they are a different size. Or ide sent u some. But call polk and get tje right size or maybe someone here will know the right size and order them .Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Thanks soundfreak1, I'll see if someone will chime in as to what size I need. I was hoping the were a uniform size.Monitor 7C's With Tubes
Parts express has them.http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=821&CFID=16358662&CFTOKEN=75360108 Here ya go.Dan
Thanks Dan, any idea what size I should be looking for?Monitor 7C's With Tubes
I'm not sure on your speakers,if you can get a measurement on one of the old ones go from that.If not there's the magnet set.
my cs300 center needed them I used a piece of hardwood dowel I checked if they snapped in after that I pushed them in to a correct depth and with a blob of exoxy on them Ipushed the frame in place on the speaker , next day I carefully pulled the grill up with the new pin now attached and put a bigger blob of glue on to fix the area , a touch of black paint and its perfect .
Thanks for the responses, I'm gonna measure them and then go from there.Monitor 7C's With Tubes
