Need help with Tactile Transducer
MrC
MrC Posts: 5
Newbie here. I have a Denon AVR 1312 set up as 5.1 with Polk Monitors and Polk Sub, model PSW10. I want to instal two Aura Ast Transducer Bass Shakers to my system. (under couch) I'm getting different advice on how to do this.
On the rear of my sub is a panel for hooking up two sets of speakers.
Can I simply connect the bass shakers to these speaker connections and share the sub's built in amp or do I need to install a separate amp to drive the two bass shakers and come off the AVR? Thanks!
Post edited by MrC on
  • ambiophonics
    ambiophonics Posts: 727
    edited February 2012
    Welcome,
    The speaker level outputs on your sub are only active when run a speaker level signal into the speaker level inputs on the sub - it's basically a pass-thru. You would need a seperate amplifier to run your tactile transducers. I think there is a topic somewhere with a bunch of info on your sub which may help explain the inputs/outputs a bit better for you.
    http://www.polkaudio.com/forums/showthread.php?40723-Making-connections-to-PSW10&highlight=PSW10
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • Serendipity
    Serendipity Posts: 6,975
    You would need a separate amp to drive the bass shakers as the speaker level outputs on the sub will not output any signal if the RCA (line-in) connectors are used.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
