Fxi A6 , driver which side
Nerd
Nerd Posts: 68
edited February 2012 in Speakers
I just picked up a second hand pair of FxiA6.
I want to place them in dipole, in 42" high stands. I did not see any marking saying left or right and no arrows.
So how do I place them ? Is the woofer to be put towards the TV side or the opposite side
Sorry if this is a stupid question
Polk RTi12
Polk Csi A4
Polk FxiA6
Outlaw LFM-1 EX
Onkyo TX SR806
Adcom GFA 555 MkII
LG 55" 3D 55LW6500
LG Blue ray BD670
Post edited by Nerd on
    F1nut Posts: 51,778
    They should have a sticker on the back under the binding post plate. Anyway, I have mine on the back wall, in dipole with the driver towards the side wall.
  • jbooker82
    jbooker82 Posts: 1,627
    woofers face the listening postion when use on side walls.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Nerd
    Nerd Posts: 68
    Yesterday, 09:25 PMF1nut
    They should have a sticker on the back under the binding post plate. Anyway, I have mine on the back wall, in dipole with the driver towards the side wall. .
    They don;t have anything on the speaker, I checked everywhere. I will have mine on the sides at 90 degrees to the listening position, so should it face the screen or the back
    DSkip
    IIRC the woofers should face the screen if on the sides and the opposite wall if in the rear. If you install them on the side walls, try to get them somewhat behind you.
    OK thanks.
    jbooker82
    Thats confusing, cos the listening position is 90 degrees, so as per the comment above, should I place the surrounds a little back from the listening position.
    If I cannot place them behind due to constraints, then where should the woofer face ?
    Polk RTi12
    Polk Csi A4
    Polk FxiA6
    Outlaw LFM-1 EX
    Onkyo TX SR806
    Adcom GFA 555 MkII
    LG 55" 3D 55LW6500
    LG Blue ray BD670
