Sda 2 polk spkrs serie 20825 .
PW47
PW47 Posts: 76
edited February 2012 in 2 Channel Audio
INEED THE CABLES FOR IT THE BOTH CABLES THE BLADE AND PIN ? AND ILIKE TO KNOW HOW THOSES CABLES WORKS AT THE SDA 2 ? IKNOW THE ORIG CABLES IS OUT . SO SIMILAR JUST WILL BE VERY FINE . INEED TO PUT THOSES BEAUTYS TO WORK . FOR MY ACURUS . THANKS :loneranger:
Post edited by PW47 on
  • ambiophonics
    ambiophonics Posts: 727
    umm... SPAM?
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • evhudsons
    evhudsons Posts: 1,175
    Bad English on a good drunk, most likely.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    PW47 wrote: »
    First of all, just WOW.
    The dimensional drivers don't work if the cable is not installed. Which means, your using 2 of the 4 mid drivers. The dimensional drivers are what makes SDA's (Stereo Dimensional Array) SDA's. With out them working, the speakers aren't being used as they were intended.
    Polk doesn't make the pin/blade cables anymore but what you can do as a temporary fix is put some speaker wire in the "pin" hole on both speakers and make sure it's snug (maybe some 14awg?). Make sure it's snug. The blade doesn't do anything but hold the pin in place so don't worry about that.
