Using the correct terminals..
Riskay
Riskay Posts: 9
edited February 2012 in Speakers
Scroll down to bolded line to skip the BS.
After wiring my car in preparation for a pair of Polk Audio DB651 and a pair of JL Audio 6w3v3-4, I ran into a little problem with the door speakers (DB651).
I used 12 gauge speaker wire to run to the doors -blah blah blah over kill, I get it, but it's what I had on hand and it doesn't hurt my system in any way. Only problem I'm having is connecting a 12 gauge wire to the male disconnect terminals on the DB651. I think the males on the speaker are meant to connect to one 0.187" (+) and one 0.110" (-) female disconnect -just a guesstimate.
I want to avoid soldering. And they do not make any 10-12 gauge female disconnect terminals in 0.187" and 0.110" for audio (gold plated). Dorman used to (part no. 84552/84553) but discontinued the item (why?). However Dorman does make them in 14-16 gauge (part no. 84546/84547).
Would it really be so bad to trim the wire down to a 14 gauge from it's 12 gauge size?
I definitely don't want to damage anything. The only negative thing I can think of is maybe a loss of signal.. what else should I expect if I do this?
Post edited by Riskay on
  • Glowrdr
    Glowrdr Posts: 1,103
    Shouldn't be an issue. If you don't get much of a response, there is a seperate car audio section you may want to post in
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • Riskay
    Riskay Posts: 9
    Thanks, I appreciate the response.
    I'll try posting in the car audio section for more responses/ideas.
  • steveinaz
    steveinaz Posts: 19,538
    Not an issue, I'm guessing you've already tried twisting the **** out of them? Possibly twisting them, then tinning w/solder; then filing the bundle to fit?
    I used to use this method to get 12ga wire into vintage receivers spring loaded speaker connectors.
  • Riskay
    Riskay Posts: 9
    Nope, haven't tried with the 14 gauge terminals yet. I was planning on picking them up today to give it a shot.
    Thanks for your help! I'll try that method and if I can't get a nice connection, I'll probably just cut it down to fit the 14 gauge.
  • PW47
    PW47 Posts: 76
    Ineed the interconnections for the pin and blade ? And i like to know the fuctions of it . Ialso like to know about some upgrade for it . But the point is to get it on correctely . Thanks
