Sda interconnect
CowboyRJB2
CowboyRJB2 Posts: 58
edited February 2012 in Vintage Speakers
I needed an Interconnect for my SDA-1Cs with a pin/blade configuration, which Polk no longer makes. BUT I did find the cinch plug @ newark.com part # 29F507, which is pin/blade, so now I can make my own according to Techniciam KIM @ Polk Audio.
I HOPE THIS HELPS
www.newark.com/cinch/p-202-cct/connector-din-audio-plug-2way/dp/29F507
ELITE VSX-99 REFERENCE
ELITE PD-65
SDA-1C's with new RDO194-1 tweeters as MAINS
MAGNEPAN TYMPANI 1D's for alternate fronts for classical music
PARADIGM REFERENCE CC-450 Center
MONITOR SERIES II... M10 REARS
2 POLK DSW-600PRO SUBS
"ROCKIN THE HOUSE"
Post edited by CowboyRJB2 on
    F1nut Posts: 50,758
    That is a 2 pin DIN and while it looks like a SDA pin/blade the size and spacing is different enough that it will not work.
  • thsmith
    thsmith Posts: 6,082
    Hot glue the hell out out the P/B inside the cabinet because they leak air big time and add a Cardas binding post and use spades, banana's or bare wire. Huge improvement over OEM cable.
    I am testing AQ T4, KK TC4 and TC8 right now.
    The AQ T4 killed the stock 22+ year old cable. Stomped on it and walked away.
