amp for 2 mm2124 subs
Systems
hello will a phoenix gold qx 900.1 work will with 2 of these new subs ? the amp will go upto 1100 watts max
Testing
Testing
Testing
Testing
Testing
just a quick heads up, Max is meaningless, never quote max or you seem like a fool to all who truly know car audio, use RMS for all ocasions. just fyiHemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax.
contrary to popular belief...we dont memorize the specs of every sub and amp known to man...find the amp online...copy and paste the specs....find the rms value of the subs....post that....and well be glad to help
-Cody -
900watts rms 12 volts 1000watts rms 14.4 1100watts 14.4 dynamicTesting
Testing
Testing -
at 4 ohms....2ohms...what?
-Cody -
Yes that amp will work fine, it's a 400 watt RMS sub, you'll be feeding about 1000 to two, sure. Good combo."The Big C"
