LSIFX ...........$429 Shipped
gwh
I bought these off Ebay a couple years back, they work great but have some scratches on the bottoms from the previous owner and one grill has some small holes toward the bottom.
Will ship in original box with original packaging.
I also have some naked 9's in another listing and would be willing to meet anyone who is local and knock off a little on the price on both.
G
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
I need $380 in my pocket for these after shipping and PP fees if they apply.
50 Lb box 24 x 20 x 17 from 73505.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
PM sent
Okay these also have scratches on the top I forgot about when I put them on the wall.
Price reduced to $325 + shipping + PP fees if they apply.
Box is 50 Lb box 24 x 20 x 17 from 73505 via UPS.
If you have an account with this shipper or another and would like to use it that would be fine as long as they can pick up the package at my location.
Maximillain has first right of refusal since he has expressed interest.
Left channel pics...........HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Right Channel..........HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Sent payment as discussed. I tried to send you a PM but your inbox is full.
SOLD
Inbox is now clear.HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
this with the lsi9s would make someone very happy good deal you got there maxOnkyo 805, RtiA5s, Csi5, Rti6s
Hopefully. Running FXi3's for the rear right now along with LSi9's and an LSiC for the front. The rear does seem a little weak. Hopefully with these the rear will liven up a little as well as being tonally matched (not a huge deal since they are the rear). If not, this will be just the first step to getting into a 7.1 system.
These came today and I have them mounted on my back wall. They arrived safely although the box won't survive another trip.
I have a question on their use however. Please anyone chime in. I have them set to Bi-pole since they are the only surrounds (5.1). For some reason the sound seems to come only from one side of the speaker. I tried changing the switch but it doesn't make a difference. I tried a movie and my AVR's test signal. I'm driving these with an Adcom GFA6000. The one side is plenty loud but the other side is almost inaudible. Both the outer sides (side without the switch) are low. I also tried setting them to large in my AVR's setup. Same thing.
This seems like a setup issue rather than a shipping/damage issue. What am I doing wrong? -
I just ran the test tone out of my B&K receiver on a new pair of LSIFX's and there is a 10 DB difference on each side of the speaker. It's the design of the speaker.
Check out the crossover info on the product page.
http://www.polkaudio.com/homeaudio/lsi/specs.php#surroundI
Regards,
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Thanks. Found this thread about the issue too:
http://www.polkaudio.com/forums/showthread.php?19389-Question-about-LsiFx
From the spec page it seems that the tweeters should be outputting the same. I did my testing late last night so couldn't really test too much. I will pay more attention to the inside tweeters tonight. They did seem rather quiet last night.
Thanks.
