Cabinet cooling fans
fjross
fjross Posts: 183
edited February 2012 in 2 Channel Audio
I was wondering if anybody has any advice on a cabinet cooling fan, and where to purchase. I was reading that some computer fans are kind of noisy when there running. I"m having a custom cabinet mad with a removable back so I can slide all the equipment in, and then hook up all the interconnects before installing the back. I would like to be able to mount the fan in the 1/2" removable back. I am currently running all gear thru the PS Audio AV 5000, so I was hoping to just plug the fan into the line conditioner so it would come on with the rest of the equipment.
Thanks Dave
Mcintosh MC-501 mono blocks
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
MIT 3.3 Shotgun biwire speaker interface
MIT 3.3 Shotgun XLR interconnects
Polk 2.3TL's Gimpod boards/F-1 modded crossovers/dynamat/JB weld/Larry's rings/Blackhole 5 strips
Polk 3.1 TL's mint/stock (purchased new)
Polk SDA-2's
Post edited by fjross on
  • brgman
    brgman Posts: 2,859
    I’M OFFENDED!!!!
  • brgman
    brgman Posts: 2,859
    I’M OFFENDED!!!!
  • WilliamM2
    WilliamM2 Posts: 4,804
    I use two of these mounted to the back of the cabinet:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835186121
    I run them off a 5v wall wart instead of 12v. They were quiet to begin with, but on 5v you can't hear them at all, even a foot away. Sadly Newegg doesn't seem to have them anymore, but you may be able to find them elsewhere.
  • brgman
    brgman Posts: 2,859
    I’M OFFENDED!!!!
    EndersShadow Posts: 17,687
    Coolerguys.com
  • fjross
    fjross Posts: 183
    brgman wrote: »
    I was thinking a bit smaller.
    Mcintosh C-45
    Mcintosh MVP-871
    PS AUDIO AV5000
    Polk SDA-2's
  • rjcardinal
    rjcardinal Posts: 11
    Added cooling fans to an audio cabinet years ago.
    Be prepared for the dust that will accumulate in the cabinet and on the componets.
    Ron
  • fjross
    fjross Posts: 183
    rjcardinal wrote: »
    Ron
    I was hoping that the cabinet would help with the dust issue. I was thinking of a hinged glass door on the front. Are you saying that the fan will pull in the dust from the room into the cabinet? Maybe if I purchase one with a speed control that I could just move enough air to disapate the heat generated.
    Mcintosh C-45
    Mcintosh MVP-871
    PS AUDIO AV5000
    Polk SDA-2's
  • rjcardinal
    fjross wrote: »
    Yes the fan will pull in dust from the room. The more flow you have the more dust. Definetly use the least amount of flow to remove the heat. Dusty cooler components are certainly better than crispy overheated ones. Just be prepared to vacuum the cabinet and components from time to time.
    Ron
    pitdogg2 Posts: 26,928
    even with no fans my rack gets pretty dusty with glass doors.
  • specd_out
    specd_out Posts: 505
    Just a few things to remember.
    Always use the fans for exhausting heat, not blowing in. Blowing it can cause pressure differences and cause heat pockets.
    Run the largest cpu fan you can. Larger Fans run slower and create less noise but still move alot of cfm. I have a 230mm over my elite. dead quiet but cools better then dual 120mm fans, that where much louder.
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
