SDA 2B Crossover Rebuild
frickingruvin
frickingruvin Posts: 10
edited February 2012 in Vintage Speakers
Just acquired a pair of these. They are all original. I'm in process of replacing the tweeters, and one mid (MW6503), but am thinking the crossovers can stand a cap and resistor replacement. Most of the threads are on different SDAs, so wanted to ask for some insight on parts and any experiences you may have. Brand of caps and resistors, tolerances, etc... In addition, do the inductors require replacement? I've read in the forum that many have added Armaflex and Dynamat when these are apart-is that recommendable as well? Mine are the studio version I believe-they are approximately 65 pounds (one tweet, two mids and a passive) with a blade/blade IC.
Someone told me to remove the polyswitch in the circuit, as it is a tone robber. What is the consensus here?
They already give a pretty good sound. I'm pushing them with a Mac C32/MC2125...
Thanks in advance for your insight.
Post edited by frickingruvin on
    F1nut Posts: 50,758
  • frickingruvin
    Thanks F1..That link isn't working.
    F1nut Posts: 50,758
    Works for me. It's a search link, which takes you to many threads/posts about the 2B's. You can search though them to cull the info you desire.
  • halo71
    halo71 Posts: 4,606
    Does not work for me either. I get "vBulletin Message
    Sorry - no matches. Please try some different terms."
    --Gary--
  • audiocr381ve
    audiocr381ve Posts: 2,588
    halo71 wrote: »
    +1..
  • frickingruvin
    Thanks F1....I have been searching the site for threads pertinent to my question. As I mentioned in my original post, most are a few years old. Are the caps built today the same values? Have any of these values been improved upon? Are the tweets and mids now offered by Polk the same quality as in years past?
  • audiocr381ve
    Caps are the same values.
    The direct replacement tweeter for your 2B's is the RD0-194, and is indeed BETTER than the original SL2000. Their is also a "TL" mod that involves tweaking the crossovers a little bit to use the even better RD0-198. It's a polk approved mod and I highly recommend it.
    The replacement mid drivers from Polk are just as good as the originals. You'd be fine ordering a MW6503 from them.
    F1nut Posts: 50,758
    Weird, but then again the search function here is simply awful. Use the Advanced Search at the top right, type in 2B*TL. I recommend jumping right to the TL mod as the RD0198-1 tweeter is better than the RD0194-1.
  • frickingruvin
    Thanks audiocr: Is it necessary to change the inductors when recapping the crossover? I've already purchased the tweets and mid, so my next act is to order the crossover parts I need in order to revamp them. What is your opinion on the Dynamat and Arfaflex applications? From what I read here on the forum, they are also a good idea....
  • audiocr381ve
    No problem!
    Yep, the Dynamat works well and takes the "ring" out of the mid drivers and passive radiator.
    If you're looking for more bass slam then the inductors are a good idea. Solen sells a 16mH 10awg that would work well. It's a pricey mod. I have the stock inductors in now and with 225 wpc, the bass is absolutely fine.
  • inspiredsports
    inspiredsports Posts: 5,501
    You are on the right track as those old caps and resistors are most probably at the very end of their life expectancy.
    You can use original values and drop in RDO194-1 tweeters, or bypass the initial 2.7 ohm resistor with an additional 5.8 uf cap and upgrade to the RDO198-1 (I like the 198 "TL" mod best).
    Find the thread by "Face" where he used Clarity Caps and Duelund resistors (Sonicaps and Mills resistors would be a close second).
    Dynamat on the baskets of the 12" passive radiators and 6.5" drivers, new gaskets on all drivers and the binding post mount, Larry's Rings, and new (I like Cardas) binding posts will let those 2B's run with speakers costing an incredible amount more.
    P.S. Replacing the big SDA circuit inductors helps (in my humble opinion), and an upgraded SDA interconnect cable also yields improvements.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • frickingruvin
    Are Larry's rings still available? In the threads I have read abouth them, it appeared they were no longer available...
    F1nut Posts: 50,758
    They are no longer available.
  • frickingruvin
    I received a pair of 194s, and one 6503...am going to drop those in for the time being...still am yammering over the recap...I know that has to be completed, but am going to exercise a little patience and listen/rework these in steps, and try to gain knowledge as I go forward.
    Not much input on the the polyswitch removal. What are your experiences with this mod?
    F1nut Posts: 50,758
    Remove it and either replace it with a jumper or a resistor to keep the same resistance that was designed into the circuit. I prefer a .5 ohm, others like a .22 ohm.
  • frickingruvin
    Thanks F1:
    What type of music represents the majority of your listening? I'm sure if you are of the "trebley" or "midrangey" music your resistor selection would be made accordingly....
    F1nut Posts: 50,758
    Good music.
    It will depend on numerous factors as to your preference. Experiment for yourself to find yours.
