CD Player
drselect
drselect Posts: 664
edited February 2012 in Wanted (WTB) Classifieds
The CD player went out at the gym that my daughter takes gymnastics so I volunteered to find a replacement. Don't need anything fancy would be nice if you could easily select different tracks without going through a sub menu and preferably with a remote. Trying to stay in the $50 to $100 range including shipping.
Thanks.
Post edited by drselect on
    gudnoyez Posts: 8,174
    Was it a single disc player, a 5 disc player, a mega disc player if the listening is not that crucial at the Gym, look at the Craigslist in your area or a pawn shop, was the cd player hooked up to a decent system or was it a boom box type?
  • drselect
    drselect Posts: 664
    They had a single disc player connected to a denon AVR ( no boom box) but a 5 disc player would work. I didn't have any luck with craiglist and didn't want to risk a pawn shop.
  • EDUBAG
    EDUBAG Posts: 403
    usually sonystyle stores have open box units within your price range, the local best buy as well. i remember i saw a 5 disc sony cd player in such store for like 40 bucks.
    good luck,
    eduardo
    HT:
    POLK AUDIO RTI4 FRONTS
    CSI3 CENTER
    DEF TECH PROMONITOR800 SURROUNDS
    PSW 125 SUB
    PIONEER ELITE AVR23TXH AVR
    APPLE TV 160GB
    PANASONIC BLURAY PLAYER
    50" PANASONIC PLASMA TCP50C2
    2 CHANNEL:
    KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
    OPPO DV980 (AS CD PLAYER)
    PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
    MIT EXP2 SPEAKER CABLES
  • drselect
    drselect Posts: 664
    Nearest BB is 80 miles away so with gas and a good meal/drinks I would have more than my budget into it. Was hoping someone had one boxed up seating in a closet needing a new home.
  • cambir
    cambir Posts: 1,046
    I have a 5 disc Harman Kardon I picked up recently. I wanted the receiver, but this had to be bought with it. Seller didn't have the remote, though. It would definitely be within your budget as long as shipping isn't too bad. I can check the model when I get home and also make sure everything works. Let me know if interested since it has no remote.
    Also have a Rotel RCC-955 changer with remote, but it may exceed the budget with shipping.
    mhardy6647 Posts: 35,315
    Always have something "in stock" :-)
    I can send you one from 'the collection' for the cost of postage - PM me if you're interested.
    The only problem is that I don't have remotes for most of them.
    Probably something like this -
    The trickiest part is finding a suitably-sized box!
  • cambir
    cambir Posts: 1,046
    HK is an FL8300 from 1996; no remote; functions very well; appears it may not support CDR/MP3 format. PM me if interested.
  • gdb
    gdb Posts: 6,012
    Get a new, low priced DVD player at Wallyworld that includes a remote control. Amazon will send you a Sony for $29.88 to your door if you avoid going to Wallyworld as much as I do.:wink:
    http://www.amazon.com/Sony-DVP-SR200P-DVD-Player-Black/dp/B001IBHUU8/ref=sr_1_15?s=electronics&ie=UTF8&qid=1329542420&sr=1-15
  • drselect
    drselect Posts: 664
    Thanks for all of the replies. Sorry it took so long to post back. I am still waiting a response from the coach to make sure the remote is a would lik-e to have or a must. I am going to send pms to verify shipping costs. gbd-the coach said he checked at walmart and did not like the dvd/cd combos they had because it was difficult to jump between tracks.
  • drselect
    drselect Posts: 664
    DSkip wrote: »
    I'd rather it not go in this instance because I don't think it'd be a good fit since I don't have a remote and it might not read those burned CD's. It definitely doesn't support MP3.
    Has the coach thought about using an iPod or MP3 player as a source? seems that would be a lot easier and you could find an older gen in that price range.
    I am not sure if he thought about the ipod/MP3 player as a source. I know that the cd they use was something the USGA sent them. I will check with him
    I know this was brought about by someone else also about supporting MP3. Ok this question is going to show how little I know but if someone burns a cd from a MP3 formated source does the cd player need to support MP3 format?
  • drselect
    drselect Posts: 664
    Thanks DSkip for the reply. I understand the *should*.
    a plain-vanilla, 'redbook' CDP is en route even as I type this - hope it gets the job done!
  • agfrost
    agfrost Posts: 2,477
    Good on ya, Mark! The gymnasts will be somersaulting to tunes later this week!
    Jay
  • drselect
    drselect Posts: 664
    Thanks mrh, the cdp arrived in great shape (nice packing job). Gave it a test run and everything seemed to be in working order. Hopefully will get hooked up in the gym on Monday.
    drselect
    De nada; hope it's "fit for purpose"!
