Power cable for my blu-ray player
ViperZ
Looking for ~3' a/c power cable for my Oppo. Thanks!!
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
B&W CDM1-SE fronts
B&W CDM-CNT center
Post edited by ViperZ on
WHat type is it, standard IEC or C7 ?
I just bought a PS Audio C7 for my Mac Mini.Speakers: SDA-1C (most all the goodies)
It's a standard IEC connector. Thank you for clarification. I am using a heavy-duty 12 (or even bigger) AWG cable right now, and it's very heavy and not suited for the application. Ideally I'm looking for a good quality 14 AWG 3' cable.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Monster AVL-300, HTS-2500 MKII -
That's what it came with. I am looking for something better to try. Thanks!Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
I use a couple of these in my set-up. I can't compare it to the big boys but can tell you that its an improvement over stock!
http://www.amazon.com/Pangea-Audio-AC-14-Powercord-Meter/dp/B0030ERI1W/ref=sr_1_3?s=electronics&ie=UTF8&qid=1329425483&sr=1-3Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Thanks rooftop. I ordered signature version for 49.99 (1m). Will see if it makes any difference.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
