RM8 Center Speaker Terminal Replacement
sonofjorel
The red clip on my Polk Audio RM8 Center Speaker broke off. Polk Audio sent me an entire terminal replacement and I need some guidance. It looks like the screw that holds the terminal in place is under the clips. How do I get the terminal off so I can replace the broken clip:question:
