Squeezebox connection upgrade
brgman
brgman Posts: 2,859
edited February 2012 in 2 Channel Audio
I am adding a new HD to my computer and was looking at sound cards.I currently have an ethernet connection from my Cisco Network to the squeezebox and wanted to know if i installed a ASUS sound card with SPDIF would i be better off running a coax line from the pc to the SB Touch or would it not matter much for sound quality?
Not interested in wifi for the SB.Too many wifi things pulling at it already so i prefer a solid connection.
Suggestions please?:question::confused:
I’M OFFENDED!!!!
Post edited by brgman on
  • mdaudioguy
    mdaudioguy Posts: 5,165
    I think your only choices are wifi or ethernet. The SB does not have audio inputs - only RCA and optical outputs. Otherwise, I'm confused about what you're trying to do...?
  • steveinaz
    steveinaz Posts: 19,545
    You'll have to go ethernet.
    heiney9 Posts: 25,403
    Soundcards are generally a bad choice for the best transfer of music. What on earth are you trying to do? Go Ethernet or wireless, there is no other choice.
  • brgman
    brgman Posts: 2,859
    Damn I should have woke up more before asking
    I forgot the coax is an output
    never mind......
    I’M OFFENDED!!!!
    Try the wireless, you'd be surprised how much you can run on it. If not, then your only alternative is ethernet for a hard wired input.
