speaker matching
was wondering if my speakers are a good match, i just purchased rti70s to replace my rt600s, i am using my rt600s as my rears replacing rt15s, my center is cs245 and im powering it with a h/k 225, im running 2 subs, one is a yamaha 60w and the other is a 100w no name that was given to me, (the walls shake as it is with the subs i have) and is it recommended to bi amp my rti70s with my old kenwood 100x5?
That will work fine but your center channel is now out of line. You need to step up to the 40/400 series. It will make a big difference.
70 percent of your front stage is your center channel and it is smaller than the rest of your speakers.
