Krell ClassA
solster
solster Posts: 2
edited February 2012 in 2 Channel Audio
How can I tell if this the KSA80, or the KSA200?
Post edited by solster on
  • cstmar01
    cstmar01 Posts: 4,424
    If you have the SN call Krell and ask them. It should be on record what it was. Also if your buying the seller should really know what they are selling if they don't well I wouldn't trust them too much.
  • nwohlford
    nwohlford Posts: 700
    I assume that you don't have any other pictures of the amp. The easiest way to tell from a picture is by the sets of fins on the side. The KSA-200 should have three sets on each side and the KSA-80 should have two sets (The 200 is 28 inches front to back and the 80 is 21 inches).
    pitdogg2 Posts: 25,764
    Sorry I'm not any help, but I must at least state I'm a little put off by the cheap looking binding post on that high dollar piece of equipment....
    Just saying I've seen better looking BP's on some high mid level receivers is all. But then again they might be top notch and I'm just not seeing it.
    carry on.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    Wizzel to the fizzel solstizzel
  • FTGV
    FTGV Posts: 3,649
    ..t least state I'm a little put off by the cheap looking binding post on that high dollar piece of equipment....
    carry on.
    Those Superior BP's are actually quite solid and were/are used by numerous companies hi end and otherwise.
    FTGV wrote: »
    Well that is nice to know from the picture they look like the off the shelf .99 cheap o's from parts express.
    To the OP sorry no offense was intended
    Thanks Fred
