Turntable Suggestions
newbie308
newbie308 Posts: 800
edited February 2012 in 2 Channel Audio
I am currently running a Technics SL1200 turntable with the stock tone arm and Cardas wires. I like the simplicity of the direct drive and the ability to swap cartridges with the p-mount for different records, but I'm tired of running to the turntable at the end of every record to prevent the thump thump thump of the needle. I'd like to replace the SL1200 with a similar unit with an automatic lift feature. What do you suggest?
Post edited by newbie308 on
  • newbie308
    I forgot to mention that I'd like to keep it under $1000.
  • thsmith
    thsmith Posts: 6,082
    I do not know of any decent modern turntable with auto return. There are a lot of old 70s TT on ebay with auto return but will be a step down IMO. Keep your eyes open for a accessory that would mount to any TT and auto lift the tonearm at the end of the record. Probably not cheap if you find one but would be a better option.
  • thsmith
  • thsmith
    I found the guy on ebay that sells the levitator. $95.
    FOr a grand you could pull off a lot of very nice tables and cart. Add the levitator and your set.
    Much better off than going to a 70s TT with auto return.
    nooshinjohn Posts: 25,877
    fastz28 wrote: »
    The yamaha px-3
    You would have to spend over a grand to get anything better.
    http://www.youtube.com/watch?v=gJhY46LyogI&feature=related
    You can find these on ebay $250 to $600
    I can second that. I love mine. It was new in the box for 400 bucks, and I have it paired up with a Sumiko BPS EvoIII. I don't think I could do better for less than 3k.
  • gdb
    gdb Posts: 6,012
    Thorens TD-145
  • gdb
    gdb Posts: 6,012
    thsmith wrote: »
    Got a link for him ? My search on ebay didn't turn up anything.:sad:
    SCompRacer Posts: 9,078
    gdb wrote: »
    Try this....looks like he wants contact via email.
    http://wiplastics.com/page05.html
  • gdb
    gdb Posts: 6,012
  • rebuy
    rebuy Posts: 695
    thsmith wrote: »
    A lot of good turntables were made in the 70's like Dual with auto return and a kitchen sink.
    Sure, you can buy fancier looking tables but there are good vintage tables out there.
    After all, that's what we had to work with, turntables.
    I've owned a couple of AR turntables and some auto brands too.
  • gdb
    gdb Posts: 6,012
    The Thorens TD-145 is an end of play- lift arm type, no return mechanism. Otherwise, it's identical to the famous TD-160.:wink:
  • BlueFox
    BlueFox Posts: 15,251
    gdb wrote: »
    Some more at different price points:
    http://www.audioadvisor.com/prodinfo.asp?number=THTD158
    http://www.audioadvisor.com/prodinfo.asp?number=THTD1902
    http://www.audioadvisor.com/prodinfo.asp?number=THTD235
    http://www.audioadvisor.com/prodinfo.asp?number=THTD295
  • newbie308
    Wow! Great suggestions guys!Thanks!
    I'm going to try the Levitator first, but I realy like that linear tracking TT! I have had a few Thorens turn tables, but I prefer the simplicity of the direct drive and the adjustability of the tone arm on the sl1200.
  • CSM41
    CSM41 Posts: 55
    I had a Thorens TD 145MKII at one time. In fact, I still have it. It sits on a shelf in my basement. I hope you have a nice solid place to put it. Sprung TT's are prone to footfalls, etc.
    Besides, how many great modern TT's have you seen that are automatics. NONE. You were doing well with the SL-1200. A good turntable. Mod it and you'll have a great TT.
    #1 Pass F5/Dared Sl2000a/Nola Boxers/Basis Audio 1400/Audio Technica AT33EV Phono Cartridge/Cambridge Audio 640P-Hypno Modded/GF DAC09/CPU
    #2 Cayin A-50T /Hornshoppe Horns/Squeeze Box Touch/Simaudio Moon 100D DAC/Rythmic F12 Servo Sub
    newbie308 wrote: »
    The PX-2/3 and other linear trackers are mostly direct drive units as well, and with regards to adjustability, they also have fewer needed adjustments because they track the record in the same way the record was mastered to begin with. The only adjustment needed for my table was making sure the table was level, the cartridge properly installed, and that the tracking force was correct.
