My website is back up
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited February 2012 in The Clubhouse
Take a look and leave some feedback please.
www.bigaudiofanatic.com
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • Serendipity
    Serendipity Posts: 6,975
    Looks great!
    The only thing I would suggest is a list of what you can do, such as remote starts, alarms, head units, custom fiberglass work, amps, speakers, etc.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • bigaudiofanatic
    Looks great!
    Good idea, you think that should be on the front page?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Serendipity
    IMO, it depends on the layout you are going with on your site. If you want to put an intro page and say something like "Hi my name is Matt and I am a car audio enthusiast, I do quality work and treat your car better..." then describe the services offered, that can work.
  • bigaudiofanatic
    We will be working on that stuff in the next few days.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • ryanjoachim
    ryanjoachim Posts: 2,046
    Also, there are several spelling and grammatical errors to be had.
    A small issue, to be sure, but one that matters to some.
    I can give examples if you would like.
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • Serendipity
    Also, outputs are low impedance and should be connected to high impedance inputs.
    For example, if you have a subwoofer with a 4 ohm single voice coil, that sub can be connected to an amp which has a low impedance output capable of driving a 4 ohm load.
    Your website says "For example, if you have a subwoofer with a 4 ohm single voice coil, that sub can be connected to an amp which similarly has a resistance of 4 ohms."
    That sentence needs to be corrected, IMO.
  • Serendipity
    ^^ The amp doesn't have a resistance of 4 ohms, it is capable of driving a load with an impedance of 4 ohms. Impedance varies with frequency and that is known as reactance. The sub's resistance is not 4 ohms across the entire frequency range.
  • Serendipity
    One more thing I noticed:
    You can hook up a 4 ohm coil as a 4 ohm (standalone) or if you have two you can wire them as 8 or 2 ohms. If you have a SVC 8 ohm sub then you can hook it up as 8 ohms. If you have two of them you can wire them as a 4 ohm or 16 ohm load.
    Your website says "you can hook up a 4 ohm coil as a 4 ohm or if you have 2 you can wire them as 4 or 2 ohms. If you have a SVC 8 ohm sub than you can hook it up as 8 ohms. If you have 2 of them as a 2 ohm or a 8 ohm load."
  • bigaudiofanatic
    http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=41#results
    2 or 8 ohms, I will correct that, I wrote most of that in a day so you can not blame me for a error like that.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Serendipity
    Not blaming you or anything, just trying to help you improve your site.
    The last thing I'd want is for someone to connect their subs up incorrectly and destroy an amp.
    VR3 Posts: 29,658
    Looks like a personal page not a business, IMO
  • Serendipity
    I like the fact that it looks like a personal page, not a business. Shows that he's not someone who's just looking to "make a quick buck" and truly likes car audio, IMO.
    Same reason why I go to a local mechanic vs. Meineke/Midas/AAMCO/etc.
    VR3 Posts: 29,658
    I dont get what you mean..
    It is not about making a quick buck but knowing what you are doing instead of being that guy down the street...
    It does not have to be "a business" but instead of Big Audio Fantatic - maybe call it BAF and below it spell it out, streamline the site with maybe new or a highlighted install or just a small about me -
    Then have sub pages for installs and such...
  • Joe08867
    Joe08867 Posts: 3,919
    I found a possible spelling error. Are you referring to Dynaudio or DynaAudio in the JL section of Audio 101? It looks like an error the way it is written. People can be pretty petty when they see stuff like this.
    Many of you might have heard that the JL Brand is basically the best you can buy. Respectfully, this is by no means true. There are many better companies out there for around the same or less price than JL's products. A few to start with: Focal, CDT, Image Dynamics, Rainbow, and Dynaaudio. Do not get me wrong, JL is good stuff. There is just a lot more out there that you might consider prior to pulling out your credit card. I'm always happy to talk about your options.
    Other than that and the suggestions above it is very nice.
