Need help.. tire replacement in pairs?
danger boy
danger boy Posts: 15,722
edited February 2012 in The Clubhouse
My friend has a Mazda 3 hatch back... he got a big bolt in his OEM tire, and the handbook says to replace tires in pairs.. whether it's only one bad/flat tire.
is this right? very few other cars seem to ask for this.. and would it make a car handle poorly if you only replaced the flat tire with a new one?
is someone trying to sell him snake oil?
PolkFest 2012, who's going>?
Post edited by danger boy on
    F1nut Posts: 52,301
    Depends. How many miles are on the current tires? Is the exact same tire still available? I don't know what the OEM tire is on that car, is it a high performance tire or a regular passenger car tire?
  • thsmith
    thsmith Posts: 6,082
    I remember being at DIscount Tire and guy with a Subaru (I think) came in and they were having the same discussion. Maybe because it was all wheel drive (?). In any case Jesse's question s need to be answered.
  • Tankman
    Tankman Posts: 419
    +1 here.F1nut is right.It depends on how many miles are on the rest of the tires.How much tread is left on them or the wear on them.But yes tires should be replace if they are punctured.
  • danger boy
    tires are worn to the point of needing replacement.. that's ok.. but say if they weren't and then got a bolt so that one had to be replaced... would you still ditch one good tire and buy two? either way, they are 17" low profile tires... 2 tires = $495 i've learned that low profile tires wear out in half the miles that other tires do..
  • gdb
    gdb Posts: 6,012
    Not unless I had dain bramage.
    nooshinjohn Posts: 26,108
    danger boy wrote: »
    I have much experience on this, both personal and professional. It is never a good idea replace just one tire. The reason is that you end up compromising the handling of the vehicle in some way. I would get two new tires for the fronts, as these are the drive wheels on the Mazda 3. The best remaining tires should go to the rear. When it comes time to rotate them, I would get two more new ones, taking the fronts to the back.
    Be careful to get the proper speed ratings as well and never mix ratings on the same axle either as this can also lead to unsafe handling conditions.
    As far as wear goes, that statement is untrue. The wear of a tire is determined by several factors such as how the car is driven, the speed rating, and the "grip" of the tire. generally speaking, the stickier the rubber the faster it wears. Tires that are capable of high performance tend to wear out very quickly because they sacrifice wear characteristics for dynamics. If you are looking for a tire that will last more that 45k miles, you will sacrifice handling in the process.
  • cambir
    cambir Posts: 1,046
    The tires on these Mazda's wear quickly and can be expensive. Discount tire has some Yokohama's that work fairly well on our Mazda 5, shouldn't cost as much as your price above and have a decent mileage warranty. Then get their extra warranty in case your friend gets another bolt.
  • concealer404
    concealer404 Posts: 7,440
    danger boy wrote: »
    After all these years, i still don't know what "low profile" means, nor do i know why they would wear out faster. :neutral:
    Anyways, yes, i would replace in pairs, unless the remaining tire in the pair was already pretty new. Alternatively, you can have your tires "shaved" to get them to match, but that's not something i'd bother with on a normal passenger vehicle.
  • unc2701
    unc2701 Posts: 3,587
    Surprisingly, that's wrong. Handling is always best with the newest tires on the rear, regardless of the drive wheels. There may be occasional exceptions, but the rule is to always go to the rear.
    Backburner:Krell KAV-300i
  • concealer404
    unc2701 wrote: »
    I would only agree with that in winter time.
    Other than that... maybe only RWD cars, depending on how the car is used.
  • polkatese
    polkatese Posts: 6,767
    unc2701 wrote: »
    Just replaced mine a couple weeks ago. This is what America's Tire told me, new tires go to the rear. And yes, go in pair. One tire has premature tread wear due to alignment problem, he suggested and I heed to get a new pair to replace. $500+$249 for alignment later it handles better.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • unc2701
    Long standing myth. Every single tire manufacturer recommends they go on rear wheels, FWD, RWD, 4WD and AWD.
  • concealer404
    unc2701 wrote: »
    So... with my 300-350whp FWD daily driver, i should put the older more worn tires on the front, where they are tasked with doing ALL the of the accelerating, steering, and 80%+ of the braking?
    No thanks.
    They're saying that because they consider terminal understeer to be safer than the **** end of a car whipping around, in that most people who have no idea what they're doing when they drive might have a chance in hell at correcting understeer. You're also less likely to get throttle-lift oversteer with the fresh tires on the back, i suppose.
    If you know how to drive and/or don't drive like a moron, it's not really an issue. I'd prefer to have the fresh good tires on the front in my FWD cars, since they're the ones that actually do most of the work, and the **** end is merely along for the ride. I feel safer that way.
    I guess so this doesn't continue... i CAN see WHY someone might recommend that. Just saying that i'd never do that as a hard and fast rule. I bet Hoosier wouldn't tell me to put the worn tires on the front of my race car, either. :cheesygrin:
    Oops my bad... you already covered this with your first quote:
    Judging by what i see around me, i'd say that "those that can drive well" would be the "occasional exception," so screw it, i'll agree with you. :lol:
    It's interesting that 99% of car enthusiasts will rather put the tires on the front.
  • unc2701
    Will have to find it, but I think it was Road and Track: they took the manufactures to task and pretty much said your points exactly.... then took it for a whirl. In just every driving scenario, the performance was better with the tires on the rear with the exception of straight line acceleration. I was pretty dumbfounded myself, but if they're willing to eat crow and it lines up with what the tire makers say, I'm willing to go with it.
  • concealer404
    unc2701 wrote: »
    It's really going to depend on car and situation.
    But in the end... bald tires are bad mmmmmmmkay? :lol: At least that much we'll agree on. :razz:
  • unc2701
    Agreed on that.
    I got VERY sideways a couple years back w/ balding tires on the rear of my FWD car- came over a slight rise followed by a turn: had rained earlier in the day but the road was dry... until I hit the patch where construction trucks had tracked about an inch of mud out into the road just past that rise. Managed to keep it on the road, but I've never gotten the **** end of a car so far out even dumbassing around in parking lots as a kid. Got me to replace my tires, and then I got into it with the shop when they just swapped out the rears instead of rotating the fronts back. Did some research and came away very surprised.
  • concealer404
    unc2701 wrote: »
    Agreed on that.
    Yeah, when i bought my Miata in July, i drove it back from CA, about 3000 miles. The rear tires were pretty shot. I hit a very nasty storm in Kansas. SCARY. The damn thing would just NOT stay pointed straight.
  • nadams
    nadams Posts: 5,877
    polkatese wrote: »
    $249 for an alignment? AND $250/tire? Holy crap!
    Alignments around here are $60 at most. And unless you're getting some high-performance low-profile tires, $150ea is more like it.
    Ludicrous gibs!
  • exalted512
    exalted512 Posts: 10,734
    I just got new tires and an alignment on my truck...freaking grand out the window :(
    Oh well. Gotta have them. I'll spend more than that on motorcycle tires in a few months.
    And the tires I got should last 70k miles and my truck has wet traction grip better than it's ever had, so im happy. Especially with all the rain we've been getting lately.
    -Cody
