RTiA7 or Subwoofer Help
over50
over50 Posts: 201
edited February 2012 in Speakers
My wife gave me the green light to buy myself a Birthday present. My choice's are (feel free to add) are replace my A5 with A7 or keep my A5 and buy another HSU subwoofer. I usually don't get the Ok for audio stuff. Any thoughts would be helpful. Thanks
Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand
Post edited by over50 on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    What are you not happy with or trying to improve on?
    And how much of the spare change found in the couch cushions are you allowed to spend? :cheesygrin:
    gudnoyez Posts: 8,132
    I would get the A9's over the A7's or keep the A5's and go with the Subwoofer.
  • domflane
    domflane Posts: 653
    +1 for the A9's over the A7's. That would give you the most improvement for the money IMO. A 5 channel power amp might do you some good as well, a couple Sunfire's have gone here in the classifieds recently.
    - Dom
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • over50
    over50 Posts: 201
    Thanks for the reply. Newegg is out of stock on A7 & A9 , i'll keep checking and see when they have more stock . It will give me time to ponder if i should get A7 or A9. Thanks
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    Vizio P65-C1
    Universal Remote
  • gp4jesus
    gp4jesus Posts: 1,990
    Checked polkdirect (eBay)?
    Samsung 60" UN60ES6100 LED, Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga: LCR mids “Foamed & Plugged**”, inside* & out
    *soldered **Rob the Man (Xschop) LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & Mids - 981, connected w/Monoprice Premiere ICs
    Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s
