Grado Sr- 60 help - can I fix a short?
bklynNupe
So I have a short in my much loved Grado Sr-60?s .
They are a year past warranty. I called Grado and it?s 25 bucks to change the plug. I'm pretty sure the short is pretty close to the plug. Can I swap the 3.5 jack, do I need a soldering iron? Should I just spend the 25 bucks or try to diy?
Thanks.
Thanks.
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Rtia9 /csia6 / FXi A6
Samsung LN46A650
SVS PB-12-NSD sub
Audio Research SP-9 MKIII (GNSC mods)
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Audio Aero Prima CD player
Pro-Ject debut
Thanks.
You'll pay close to $40 round trip when you add the $25 repair fee plus shipping which is half of the current $79 delivered for the SR-60's from amazon.com . . . http://www.amazon.com/exec/obidos/ASIN/B0006DPMU4/websitementcommu
You definitely need to be able to determine left channel, right channel and ground, keep the wires isolated, and be able to solder and properly insulate to do it yourself without introducing hum.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
