anyone owning sr6500
ipartywhenuhurt
ipartywhenuhurt Posts: 130
edited February 2012 in Car Audio & Electronics
the instruction manual said you can bi-amp them using the crossover by removing the black things from the spikes , i hope u guys know what i mean
basically my question is what is bi-amping i tryied to google it but ended up in dead ends
Post edited by ipartywhenuhurt on
  • Vital
    Vital Posts: 747
    It's when you use all 4 channels of your 4-channel amp to power your component speakers.
    Basically each speaker (both tweets and both woofers) get their own amplification channel which helps you tune tweet/woofer ratio just the way you want it to be.
    2008 Nissan Altima
    Kenwood DNX 5140
    Arc Audio IDX and XEQ
    Polk Audio SR6500 active and SR124-dvc sealed
    Polk Audio PA500.4 and PA1200.1
  • ipartywhenuhurt
    1) how would i be able to tune it when it through the crossover?
    2) how would i know the proper rms and wouldent the ohms on the tweeter and woofer be 8 ohms??? isint that bad???
    3) what are the benefits?
  • Vital
    Vital Posts: 747
    1. crossover still does what it's supposed to - cross's (splits) frequencies going to each speaker. You tune your sound with gain on the amp (less for tweets, more for woofer for example) and whatever your head unit allows as far as tunning separate set of channels
    2. SR tweets are 4Ohms and SR woofers are also 4Ohms. 100 RMS amp will work fine for this set up just don't "crank your gain knob"
    3. See #1
    2008 Nissan Altima
    Kenwood DNX 5140
  • ipartywhenuhurt
    is biamping better than going active?
  • Vital
    Vital Posts: 747
    For the most part - active is always better but in a case of someone who just started understanding "tuning" imo bi-amp is the way to go since it'll eliminate possibly fatal mistakes which could cause your speakers to blow (too low of a frequency)
    2008 Nissan Altima
    Kenwood DNX 5140
  • ipartywhenuhurt
    so how do i bi-amp my sr6500? do i just buy a pa500.4 and put all for channels into the sr6500 like front channels for the woofer and back for the tweeter and let the fillter be on full for the amp and let the crossover do the rest????
  • MacLeod
    MacLeod Posts: 14,358
    If I remember right, there is a jumper you have to pull out of the crossover in order to bi-amp. Youll hook the front channels of the amp to the tweeters and then the rear channels of the amp to the mids.
  • Vital
    Vital Posts: 747
    Pretty much.
    Make sure you set that red jumper on your SR crossover on the right position (see manual)
    Use PA500.4's front channels for tweeters and rear channels for woofers.
    As for filters/crossovers - the only thing you'll need is to cut frequencies at around 60Hz be in via amplifier or headunit's crossover, rest will be taken care of by SR crossover.
    2008 Nissan Altima
    Kenwood DNX 5140
