Vintage Polk In-Walls
dpowell
Saw these and thought they might complement a vintage SDA home theater as in-wall center channel or surrounds. No Affiliation.
http://sandiego.craigslist.org/csd/ele/2795273138.html
Post edited by dpowell on
Interesting. Should timbre match well since the drivers were all manufactured at the same time as the last generation of SDA's. Looks like original caps - probably would be even sweeter with a Xover upgrade."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Buy 'em, upgrade the x-overs, put RDO-194's tweeters in them and thank me later. I've have a pair and they are fantastic
If I were using more vintage SDA's in my HT I would get them but the SRT's use a different tweeter and mid-driver.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
Didn't realize you had the SRT system. You're probably right, they may not match well. Does that system not come with a center channel?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I have the mains and the center from the SRT system. Using TC265i in-walls for the surrounds. I know that many on here are using the vintage SDA's for mains but always ask what would make a good matching center or surrounds. This is probably as close as you can get if in-walls work.____________________________________________________________
