New Wheels...HRE 3-Piece
dorokusai
dorokusai Posts: 25,638
edited February 2012 in The Clubhouse
I just snagged a pair of HRE 3-Piece rims for my ride...or the wife's Audi. I'm not sure where they will go at the moment but the price was silly and I've been wanting to get a set either way. The stock rims on hers suck and I'll either put my 19" Audi Y spokes on hers or the HRE on her Q5. I need to drop them off at my local wheel shop to get polished up and get a scrape fixed. They list for new for a ridiculous $2900 and I got them for $800/shipped. While not in perfect condition, their pretty tight.
What do you guys think? Mine or hers? Either way she's getting something better than the stock rims and tires she has now. I actually think they would look best on her Q5, with some nice Yokohama Parada All-Season. I'm going with those based on previous experience and a smashing great price at Tire Rack right now. Total investment on the vehicle would be about $1500, mounted, balanced, freshly polished and shined.
HRE
A5 STOCK 19" Y SPOKE
Q5 STOCK 18" 10 SPOKE
Post edited by dorokusai on
  • Drenis
    Drenis Posts: 2,871
    Polished? Yours.
    All about the stance.
  • dorokusai
    So put them on mine, send mine to hers?
  • Drenis
    Drenis Posts: 2,871
    IMO, yes.
    Your current wheels, same bolt pattern as the Q5?
  • Upstatemax
    Upstatemax Posts: 2,846
    I think the stock rims on your A5 look sexy as hell.
    The Q5 on the other hand would look nice with the new rims.
    It does not take long, just swap the rims on both and find the combo you like best.
  • schwarcw
    schwarcw Posts: 7,360
    I like the look of the HREs on the Audi.
    Time to get some gansta rims for you G5.:cheesygrin:
    Carl
  • dorokusai
    Upstatemax wrote: »
    Yeah, that's the best idea in the end.
  • Sherardp
    Sherardp Posts: 8,038
    Put the HRE on yours and put a 22 on the Q5. The Q5 will look awesome with that wheel well full. Nice and tucked baby. HRE 795 with tires for 1900.00
    http://superbuytires.com/HRE/795R/
  • dorokusai
    I'm not sure you looked at that website close enough in regards to pricing Sherardp. Plus, I already have the rims and I'm not putting 22" rims on my wife's vehicle as I'm not trying to build up a reputation or anything, just a modest upgrade is all I need.
  • Sherardp
    Yeah your right, prices are a tad insane with Superbuy as they change it up so much. Q5 is a nice truck, ride it stock or upgrade it with something a tad smaller like a 20" wheel package. If you can score another set of those 19s, those will look good on anything. I love a 5 spoke wheel with a nice dish to it.
  • dorokusai
    I love the stance of your Mercedes and the wheels compliment it perfectly. Decision, decisions....
  • Sherardp
    dorokusai wrote: »
    Thank you bro. Looking forward to seeing those mounted up on your car.
  • dorokusai
    Well, as it stands, they're going on the wife's Q5 with some new Firestone Destination ST 275/45R20. I may mount them on mine to see what they look like but I like this arrangement best so far. They come this week and there off to the wheel shop to get freshly buffed/polished and a small curb scrape fixed.
    I'm looking at OEM spec's of 235/60R18 @ 39mm offset by 8" width + 5x112. The new HRE specs are 275/45R20 @ 42mm offset by 9.5" width + 5x112. This should put them at about 6/10" further from the fender centerline which is perfectly acceptable and won't cause any issues.
    The tires come next week and we should be rolling on new shoes with 2 weeks. Since I already owned the Yokohama Parada Spec-X previously, I thought a new tire would be cool. I haven't owned a Firestone, ever and based on some research and reviews, they appear to be pretty nice. They don't have to be perfect, just better than OEM and they seem to cover all those bases. I really like the tread pattern to boot.
    This is exciting and hopefully she'll like them as much as I do....but not likely. Anyways, at least I can get the embarrasing OEM rims off and sold for a few hundred to pick up some costs.
  • shawn474
    shawn474 Posts: 3,052
    Mark,
    I have firestone destinations on my truck. You will not be disappointed.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • Sherardp
    Should look wicked on the Q5. Don't forget your Gorilla wheel locks, or your brand of choice there.
  • dorokusai
    shawn474 wrote: »
    Mark,
    Shawn - Awesome, that makes me feel much better about them. How are they in rain and if you've had them in the summer, how sticky do they get in high heat?
    Sherardp - Already locked up but have been wanting to try a set of the Gorilla brand locks. When I do the next set of wheels, I'll check them out. These right? http://www.gorilla-auto.com/gorilla-guard-locks
    Does anyone see any fitment issues with a 20" rim, 9.5" width with a 275/45-20? I can't get an exact guide that says that tire will fit that width. Does anyone have a fitment calculator?
  • maximillian
    maximillian Posts: 2,149
    I have had Firestone destinations a couple times. Nice in snow and rain. My only complaint was tread wear was a little short at 30K miles.
    Mark, I am going against the grain and saying that I like the wheels on both cars as is. But, they're your cars so do as you will.
  • Upstatemax
    dorokusai wrote: »
    The specs for that tire show it will fit an 8.5-10.5" wide rim. You're right in the middle and will be fine.
    I would mention to your wife that her speedo will now be about 2.2% off. Her speedo will read slow. The calculator I used said if it reads 60mph it should actually read 61.3 mph. I would just tell her to add 2mph to what ever it reads.
  • dorokusai
    Upstatemax wrote: »
    Thanks Upstate on the sizing. 20" are an option for this model so the speedometer isn't a problem or a worry.
    Max - Roger that. I never really expect rated tire wear so that's a given. If I get 40 maximum, Im happy with a tire. Anything else is like rolling on bricks.
  • Upstatemax
    dorokusai wrote: »
    Thanks Upstate on the sizing. 20" are an option for this model so the speedometer isn't a problem or a worry..
    The speedo is calibrated to the TIRE size not the rims... The overall diameter of the new tires is larger, resulting in a speedo that reads slower than it should.
    The speedo will be off, but well within standard specs. It should be kept to at least within 5% of factory sizing.
  • dorokusai
    Yeah, I well aware of what you mean since with bigger rims come bigger tires right? :cheesygrin: It sure would look funny if I forgot that I have to add tires.
    Point taken hoss and I'll change the wheel parameter when I install them with my laptop.
  • Upstatemax
    dorokusai wrote: »
    Yeah, I well aware of what you mean since with bigger rims come bigger tires right? :) It sure would look funny if I forgot that I have to add tires.
    Haha, I know. I'm just saying that even with 20's you can get tires that will basically match the overall diameter of the original wheels. I think the closest would be 255/45/20 tires.
    The 275/45/20 tires have a taller sidewall than the 255/45/20 so the over diameter of the wheel is "too" large.
  • dorokusai
    Oh yeah, now I got you. Yes, totally agreed. I hadn't even thought of that actually but never try to stay within spec's. Guys like big tires man and they're exciting to receive and roll around inside.
  • Drenis
    Drenis Posts: 2,871
    Pics of installation!
  • dorokusai
    Just ordered Koni street shocks for mine since she gets the new wheels. I'll post pics for sure, just hand loose guys.
