Just added a 3 TB hard drive to the comp
Fongolio
Like the title says, I just added a 3 Terabyte hard drive to my PC bringing my total storage capacity to 6.8 Terabytes. Most of it is for hi-rez audio storage and backup. The drive is a Western Digital Elements external and it cost me a whopping $169.99 plus tax. Even with the recent price increases in hard drives that's still lest than $60 a Terabyte. I remember buying my first internal 7200 rpm drive. It was 7.5 gigs and cost over $400!
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
Post edited by Fongolio on
I bought a Synology DS1511+ a few weeks ago and populated it with five 3TB
Even running RAID 5 still gave me almost 11TB of space:
Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
Amazing isn't it how much larger faster and cheaper computers and products have became just in the last 5 years even.
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all -
What's the windows index of that 3TB?SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
Nitty Gritty 1.5FI RCM -
Well, I "only" have 16TB of storage for my media/file server, but half of that is in an external RAID array for backups. So, I really only have 8TB total to work with in my file/media server, but there is no way I would go without backups; I learned that lesson the hard way (a couple of times to boot). As with Lasereath, I use an SSD as the boot drive in my laptop, and there is no way I would go back to a standard hard drive for that; it is just way too fast. I do, however, have 2 1TB drives in a RAID 0 for media storage in my laptop in addition to the SSD.
Gee... I remember my first IBM clone... 40MB HDD, Intel 386SX processor, 512K RAM... $1000. Just bought another clone a couple of years ago, dual optical drives, triple 1GB WD HDD, 16GB RAM, liquid cooled Intel Quad core i7 processor with a 1200 watt power supply for $1700...
Going further back, my first computer was an Atari 800 with 48K RAM with a 88K floppy drive... Used it to run Visicalc (spreadsheet) which could only do one page before it ran out of memory. With the Atari 825 printer, it was $3500. Probably spent more on the games... In fact, I still have one but it no longer connects to my TVs since it had a s-video connector. -
Right now i only have a 128GB crucial SSD but it gets a 7.4 in the windows index.
running an 80GB Intel SSD as my primary and get a 7.6 for the drive. Is that good? -
maximillian wrote: »running an 80GB Intel SSD as my primary and get a 7.6 for the drive. Is that good?
That's the same number I've gotten with my Samsung SSD's. Used to get 6.0 with two Samsung 7200's in RAID 0, so it's an improvement. -
You can use AS SSD and benchmark those SSD drives. This should be able to give you an idea how fast the drive performs compared to manufacturer specs. OP do you mind sharing where you picked up the external for such a great price?
http://alex-is.de/PHP/fusion/downloads.php?download_id=9Shoot the jumper.....................BALLIN.............!!!!!
I've been going the other route with my main system for years.
Trying to get the fastest drive I could in my machine.
My 160GB Intel X25-M G2 drive get's 7.6. :razz: -
When you upgrade the HD where do you put your existing files off of the original until it is installed so that you can then put them on the new HD?
I need more space.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
nice.thanks mouseMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
First internal at 7.5 gigs...dang I am old. I remember installing my 8088 math co-processor chip so I could use my suitcase sized compaq portable to compile fortran. I think I had the 40 meg drive partitioned into two twenty meg parts. The 80's are a wonderful memory.
I remember those days. Once installed an Evergreen 486 upgrade kit on a 286, and pretty sure my first drive was 40 megs as well. Used to program my own config.sys and autoexec.bat files to optimally configure the PC based on what I was going to be doing at the time. Booted them off of floppies, of course, back when floppy disks were actually floppy.
Monster AVL-300, HTS-2500 MKII -
With me music library roaring towards 500GB's I am starting to look at 1TB drives. My main storage is my macbook pro, which right now is running a 500GB drive at 7200RPM. I am going to have to give up some performance and go with a 1TB 5200RPM soon.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Does it make a lick of difference if i put a new internal HD in or just add a usb ext HD?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Does it make a lick of difference if i put a new internal HD in or just add a usb ext HD?design is where science and art break even.
bigaudiofanatic wrote: »With me music library roaring towards 500GB's I am starting to look at 1TB drives. My main storage is my macbook pro, which right now is running a 500GB drive at 7200RPM. I am going to have to give up some performance and go with a 1TB 5200RPM soon.
Skip the 1tb and go for a 2/3 TB. If your already at 500gb, you'll probably end up with like 400gb or so after format/install. I would go bigger.Shoot the jumper.....................BALLIN.............!!!!!
- Pardon my Ignorance ! What do you need all that storage space for? Beside video and audio files. Thinking about upgrading....but I am old school. Will never have the time to compress my cds again. I remember my first hard drive on a pc was 2gb and cost a wopping $200.00. Now a dvd w/4.5gb cost $.10. Amazing
I think you just answered your own question. I have nearly 1.5 TB of audio files alone. UNCOMPRESSED. Included are many SACD, DVD-Audio, and vinyl rips that can be upwards of 6 gigs. You'd be surprised how fast you can a 2 TB drive with losssless audio. If you start archiving blu ray video files uncompressed 3 TB can be used up quite quickly.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
I keep all my music uncompressed, and there is only a handfull of tv shows that make it to my HD, so most of it is music.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
3 TB 2/3 full and 2 TB backup of files on 3 TB full. I can't believe I already need a new 3TB drive for backup!! It's all SACD, DVD-A, vinyl rips and cd rips. All hi-rez.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
