Need Help with Polk psw 111 for 2.1 ch set up
dhart86
dhart86 Posts: 1,594
edited February 2012 in 2 Channel Audio
Hey........I just purchased a polk psw111 to set up a 2.1 ch system. Room is midsized and I'll use this set-up mainly for music listening (obviously)
I think I want to make connections using the speaker level ins/outs, but I have never done this with a sub.
So my questions are.....
1. Is this a recommended connection for listening to music
2. What's the proper way to make this connection
3. Is there any down side or caveats using this connection [ie: setting mains / filter / crossover]
Thanks for any help you can give
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Post edited by dhart86 on
  • NewHTguy
    NewHTguy Posts: 584
    You might want to tell people what speakers will comprise the 2 part in for them to give you the best advice.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • specd_out
    specd_out Posts: 504
    it depends on your speakers. IMO if you where to run book shelf speakers i would do a LFE out from your receiver, and set the speakers to small. If you have full size speakers or towers, I would do the sub inline via speaker cables. Set your speaker setting to large and play with the crossover on the sub.
    The reason being, that the book shelf speakers cant handle much lows and it would end up being easier letting the receiver handle the crossover. Larger full size speakers will handle a fuller range with more detail. You will be able to fine tune the Crossover at the sub and get a good synergy between the sub and the speakers.
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • dhart86
    specd_out wrote: »
    Thanks specd_out,
    I will be using bookshelf speakers Kef iQ10. I understand your explanation, however, I plan on using this set-up for listening to music. If I connect the sub via LFE, will I get info sent to the sub? I'm still figuring this stuff out, but I thought LFE was useful for (HT) dolby digital content for surround sound stuff. Is that right?
    Main Rig:
    Second Rig:
