Yamaha RX-V2400 auto setup
fireshoes
fireshoes Posts: 3,167
edited October 2003 in Electronics
Hey guys, I swapped my RX-V2300 for an RX-V2400 at work. If you haven't heard about it, it features an auto setup mode that checks speaker connection and phase; sets speaker size, distance, level, and crossover; and then measures the different frequency responses of each speaker and uses a parametric equalizer on them. The parametric eq can be set to achieve a basic flat sound, or can be adjusted to focus on low, mid, or high frequencies, or eq the surrounds to match up to the fronts. Here are the results I got in my new apartment with my LSi's.
I just moved to a new apartment last week. Over the last couple days I finally got enough things put away that I could hook up my system with some semblance of wire management. ;)
I have the LSi15's for fronts and surround backs, the LSiC, the LSiFX's for surrounds, and the PSW650 subwoofer.
All speakers were automatically set to large - default x-over of 80hz.
       Distances      Levels
FL     9.5 ft         +1
C      9.0 ft         -3
FR     9.5 ft         -.5
SL     11.0 ft        +1.5
SR     5.5 ft         -1
SBL    8.0 ft         +2
SBR    8.5 ft         +1
SW     4.5 ft         +3.5
Front Left    Center          Front Right    Surr. Left       Surr. Right
125 hz +5     63 hz -3        63 hz -9       100 hz -5.5      80 hz  -8
200 hz +2.5   100 hz +6       100 hz +6      160 hz +6        100 hz +6
500 hz -2     315 hz -3.5     200 hz +6      400 hz +3.5      250 hz +5.5
1.3 khz +6    500 hz -2       630 hz -3      2 khz +2         315 hz -2
3.2 khz -3    1 khz -4        1.3 khz +4     2.5 khz +3.5     1 khz -2.5
4 khz +2.5    1 khz -2        6.3 khz +3.5   5 khz -2         2 khz +3.5
6.3 khz +3    6.3 khz +4                     13 khz +3.5      8 khz +2.5
Surr. Back Left     Surr. Back Right
160 hz -9.5         63 hz -11
250 hz +6           125 hz +6
400 hz +3.5         200 hz +6
800 hz +2           500 hz -2.5
2 khz +3.5          2 khz +3
3.2 khz -2.5        3.2 khz -2
13 khz +5
