Need advice on setting up my system.
Hi everybody,
I wanted to see if I could get some help/suggestions on setting up my system. This is my first post!!!
My set-up
Onkyo TXNR801
(Center) CS2
(Front) Monitor 70
(Rear) Monitor 60
(Sub) PSW 505
Currently I have the the speakers set to small and the crossover at 80 Hz. I also have a spare PSW404.
Usage is going to be in the 70% HT and 30% music.
Other than knowing the room is length of the room is bigger than its with.
If been reading a lot of the articles Polk has on its website which only lead me to more confusion.
My two options I am considering right now are:
1. Keep things the way they are or
2. Change the setting on the receiver to have the front and rear set to large. Then using the PSW404 in conjunction with the Monitor 60s so the sub takes some of the load off the 60s.
I am open to any suggestions (i.e. placement of speakers, crossover setting).
Thank you.
