best sealient for cabinets?
soundfreak1
soundfreak1 Posts: 3,414
edited January 2012 in Vintage Speakers
Getting ready to mod a pair of 5jr+ speakers, they passed the preasure test ok but while I'm in there I thought I would re seal them. Due to limeted space ( can't use a caulking gun ) what would be the best way and material to use to seal them? Thanks.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited January 2012
    Maybe try hot glue. It should do the job, and the hot glue gun is a lot smaller than the caulking gun.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • Joe08867
    Joe08867 Posts: 3,919
    edited January 2012
    I used Dap wood putty for a pair of 5's once, Had to put it on by hand with a putty knife. I use Liquid Nails or something similar if I can get a gun in there.
    I don't think hot glue would hold as well personally.
    F1nut Posts: 51,700
    edited January 2012
    Hot glue isn't going to stick very well to particleboard. I recall seeing small tubes of Liquid Nails or the like recently at the hardware store.
    pitdogg2 Posts: 26,967
    edited January 2012
  • drumminman
    drumminman Posts: 3,396
    edited January 2012
    I used this on my 2.3TL's: Loctite Power Grab Heavy Duty Exterior Construction Adhesive
    Bought it at Lowes and it comes in caulking gun type tubes or smaller squeeze tubes. It literally has no odor (and no respiratory warnings), the lowest VOC's of anything I looked at and cleans up with water.
    For the tight places I put a dab on my finger and ran it into the joints. The stuff I bought dries clear.
