Harmony RF extender question
grimmace19
Alright, quick question to anyone using the harmony 1000 or another harmony that allows for the RF extender. I plan to buy a harmony 1000 for a great price on craigslist and was wondering if this could be a critical link towards a whole home audio system. Does this thing have enough range (yes i know it says 100 feet) to work from floor to floor inside of a house? For instance, with the RF extender plugged into my system upstairs could I control the entire thing from the kitchen? I'd love to be able to do this for a few reasons. I'd be able to control music and my squeezebox from the other floor and if I got a 2nd squeezebox, run them together on my two systems to get the same music in each room.
Any thoughts or other experience with the RF extender?
I thought it was "extended" as in you could use the cabled IR repeaters to control stuff from inside of a closed space? I had the Harmony One
Or do the Harmony's truely support RF?65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
The way it works is there is a little box that the remote controls via RF. The box lives somewhere in range of your audio gear and shoots IR signals at it.
The Monster AVL-300 comes with an RF extender (they call it Omnilink). I would have to go outside the house to break its range. Granted I have a small house, but I can be on the opposite side and still have no problems controlling it. Should be plenty strong enough to go through a floor.
