need help with sirius hook up to reciever
SSYNN
SSYNN Posts: 2
hi guys, im hoping someone can help me out here. i just got a pioneer vsx-921-k reciever to pair with my RTA 70's n center channel. problem is the sirius satellite connection, its a dedicated plug in which is nice, but it looks like a old style keyboard connection, circular, a couple notches to align it properly, and around 7 small pins that plug in inside the circle. i have looked everywhere but i cant find a cable that looks like it will work. any advice will help, no i dont want to cobble together a way around it, please dont offer advice how to do that, thanks in advance
Post edited by SSYNN on
  • ratster
    ratster Posts: 324
    edited January 2012
    If it is the SCH1 hook up,you can get it from Crutchfield.Otherwise you may have to pay the price @ the Sirius/Xm store.
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Clear Day dbl.shotgun
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
    Clear day dbl shotgun
  • SSYNN
    SSYNN Posts: 2
    edited January 2012
    okay that appears to be almost what i need, mine is the express rci model for a vehicle with the home dock to switch back to. i should be able to figure it out from here though. thanks a ton ratser, you rock
