input and power supply caps upgraded!
lanchile
lanchile Posts: 560
edited February 2012 in DIY, Mods & Tweaks
Hello there! a few days ago I upgraded my power supply caps and also the input caps. I use mundorf audio grade caps for power supply and Sonicap for the inputs.I had it playing for three days to "burn in" caps and so far I am very happy with the upgrade. it sounds fantastic!!! take a look.Attachment not found.Attachment not found.Attachment not found.
Make it simple...Make it better!
  • headrott
    headrott Posts: 5,496
    edited January 2012
    Looks very good! I'm sure it sounds good as well. Those Mundorf caps are very good, and with the Sonicaps it makes it even greater.
    Greg
  • lanchile
    lanchile Posts: 560
    edited January 2012
    Yeah, it is a "double pleasure" to build your own amp. first: you choose the quality of the parts you want to use and second is the feeling to know that it is "unique". it feels good!!!:cheesygrin:
  • FTGV
    FTGV Posts: 3,650
    edited January 2012
    Is that peel and stick adhesive on the bottom of those filter cap?If so thats an interesting way of keeping a two pin cap stable when PC board mounting.
    heiney9 Posts: 25,716
    edited January 2012
    FTGV wrote: »
    He recommends it
    Scroll down a bit and he explains it. I think it's a nice, simple idea.
    http://www.tubelab.com/AssemblyManualTubelabSE/Capacitors_TSE.htm
  • lanchile
    lanchile Posts: 560
    edited January 2012
    FTGV wrote: »
    yes it is. the Mundorf came like that from company! But since I did the top of capacitors on the chassis, I had to put silicone to hold them (stronger).
    I find it very clever but "only" for those "big and wide" caps. I do not think it will do much on the small and slim caps.
  • lanchile
    lanchile Posts: 560
    edited January 2012
    Since the upgrade in my power supply and input caps of my diy amplifier. call crazy but it was a big improvement.:mrgreen: Now the bass is tighter and mid/high has more detail. Sound is getting better and better!
  • PreCd
    PreCd Posts: 786
    edited January 2012
    I believe it. I recapped my am and preamp a couple of months ago - the filter caps. Still sounded dull. I then got off my billfold and replaced the filter caps and that change created a much better sounding system. Tighter bass as you explained but also more musical. Just brought my amp back to life.
    lanchile wrote: »
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
    Bottlehead Quickie Tube Preamp
  • lanchile
    lanchile Posts: 560
    What I noticed Before upgrade the caps, the dc offset was at 6mV L and 7mV R. I had to bring it down to 00.4mv in each channel. I also had to adjust the bias.
