What polk subwoofer?
jeep123
jeep123 Posts: 15
edited January 2012 in Speakers
Heavy bass is not the number one priority but these are being paired with some lsi 15/c and some surrounds.
PSW 111 vs 110?
I read that LFE in is not available on the PSW 10 or the 125. With a newer receiver with a sub pre out (LFE) how would I hook up the PSW 10 or 125 to the system? From my understanding, LFE out is connected simply with a rca cable to the LFE in on the sub and its good to go.
Post edited by jeep123 on
  • Serendipity
    Serendipity Posts: 6,975
    edited January 2012
    I would recommend the PSW111. IMO it has tighter, more accurate, and musical bass.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • NewHTguy
    NewHTguy Posts: 584
    edited January 2012
    I doubt either of those is going to complement the Lsi15s. The Lsi15s have a lower frequency response than either one. I certainly wouldn't bother for music. The subs would probably help shake the floor, if that is your goal. However, with a little patience you can get the PSW505 for less than $200 on either amazon or Newegg. I bought my 505 mainly because it was so darn cheap ($170) that I couldn't resist. But I only use it for HT. For two-channel music I use the "pure audio" mode, which does not send the output to the sub.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • specd_out
    specd_out Posts: 505
    edited January 2012
    I dont know what your plan is for the setup. For home theater I would recommend a 12" but if your looking for a music setup then a 8" is gonna be a better fit. The tighter 8" will have a nicer response for music, while a larger 12" will dig deeper
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • jeep123
    jeep123 Posts: 15
    edited January 2012
    Thanks for the replies. My initial thought was to skip the sub for a while and see how that goes. I think I'll stick to that plan.
  • jbooker82
    jbooker82 Posts: 1,627
    edited January 2012
    DSW Pro Wi series speakers are good subs especially for the cash they cost on sale from New Egg.
    You can get the 660 (12") for $349 or the 550 (10") for $299.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • blueboxer
    blueboxer Posts: 621
    edited January 2012
    You can usually find the micropros for a good price on polks ebay direct store.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2012
    Definitely micropro over any other sub made by Polk. Also take a look at some ID subs.
