Worth the $25 or not??
PSOVLSK
PSOVLSK Posts: 5,371
edited January 2012 in Electronics
http://www.amazon.com/Pyramid-PS3KX-3-Amp-12-Volt-Supply/dp/B0002JTD2K/ref=sr_1_4?s=electronics&ie=UTF8&qid=1327613428&sr=1-4
I know it's to the suggested upgrade (not even close), but wouldn't this be an upgrade over the wall wart that comes with a Squeezebox? Would there be any issues with running it even if there is no improvement?
Post edited by PSOVLSK on
  • Joe08867
    Joe08867 Posts: 3,919
    edited January 2012
    What does it come with? A wall wart or a laptop style? One is better than the other.
    I wouldn't hook that Pyramid power supple up to a squeezebox.
    There has to be a better choice out there.
  • CoolJazz
    CoolJazz Posts: 572
    edited January 2012
    Those types of supplies don't really have very good filtering at all. Also made to pretty limited price point, so what's there is generally reallllllly cheap parts!
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2012
    At least you can crack this one open and upgrade the parts if you really wish to do so.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    I have the 52 amp version and it kicks ****. There isn't a linear amplifier that I am scared of. It runs my ranger 2950 without a hickup. Now this little dude... Not a bad "Does it turn on with 12 volts? " power supply. Run longer than a quick test or two? I wouldn't. 25 bucks ain't bad.
    Too much **** to list....
