Building home theater for friend
Syndil
Just helped a friend spend a bunch of money on a brand new home theater setup utilizing an Onkyo receiver and Polk Monitor speakers, all purchased from Newegg. Some of this stuff was on sale only through 1/22, so we felt kind of rushed to buy it. Here's what we bought:
Onkyo HT-RC360 ... $329.99
2x Monitor70 Series II ... $149.99 each
CS2 Series II Center Channel ... $119.99
Monitor40 Series II ... $119.99 pair
DSWPRO 660wi subwoofer ... $329.99
Total (free shipping): 1,199.94
Since the sale ended 1/22, this same setup from Newegg would now cost you 1,689.94 today, even with the available promo codes on the Monitor70s and Monitor40s, so I'm pretty proud of the bargain. Saved $490. Nothing to sneeze at, I think.
Anyway, I think I did OK with the selection of gear, especially since he is coming from a HTIB system and he is pretty happy with that. Ignorance is bliss type thing, I guess, but I figure this new system should relatively blow his mind. On the other hand I'm not a receiver guy (I prefer a pre/pro + amp) and haven't really researched them much, so I welcome any thoughts or insights into the receiver choice. Can always send it back if I chose wrong. I am thinking that since he only has room for a 5.1 setup, I can use the extra 2 amplifier channels to bi-amp the Monitor70s.
Do not bother using the extra 2 channels to bi-amp the Monitor 70's, I tryed it with a Pioneer Elite VSX-21TXH on my old RTi-10's and it was a waste of time, no difference. What I did not understand at the time is that the receiver will NOT put out 110 watts into 7 channels simultaneously, the true simultaneous output into 7 channels is around 30 - 35 watts. In the case of your Onkyo you have about 200 watts total to feed all 7 channels simultaneously.2-Channel System
Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
Spkrs: Tyler Acoustics Linbrook Signature Systems -
As stated bi-amping from a reciever is worthless. Beyond that he's got a pretty good setup.
My only suggestions would be to make sure to place the sub in as ideal a position as possible doing the sub crawl.
Beyond that, run the Auto-Calibration software and let it take care of things for you. You can probably set the Front crossover around like 60-80 if you wanted more low end from the Monitor 70's, as I believe the auto-cal will either set them as "Full" which I wouldnt use, or @ 80hz which you can go a bit lower if you want.
If he needs mounts for the Monitor 40's tell him to get AM40 Pinpoint Mounts (~60 bucks for the set) as those are what I had my Monitor 40's on.
Enjoy!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Kind of surprised about the bi-amping. I know bi-wiring is useless, but if there are an extra 2 discrete amplifier sections that can be put into service for bi-amping the Monitor70s... Or is it that they are not discrete?
Monster AVL-300, HTS-2500 MKII -
It's more of the power behind the amp sections, then the amp sections them self.
Think if it like water, if a 1" feed pipe flows X then can it flow 1/2" pipes as .5 X four times as will as 1/2" pipes .5 X two times? The answer is NO.....
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Agreed with everyone above, hook those puppies straight up, that receiver should have no problem running those speakers. I would suggest however you read that receivers manual front to back and pay attention to the setup process involved. AVR's take alittle more to get setup right.HT SYSTEM-
lsi 9's -
Gotcha on the bi-amping. Already began reading the manual since I will be the one setting it up. Basic configuration seems straightforward but there are a lot of extra features to play with.
Thanks for the help, everyone.
