Building a center channel speaker
BigBankBii
So I'm thinking of building a center channel speaker to match my JBL LX 44's. Please tell me if I have the right idea. Use 1 of the same tweets. Use 2 of the same mids, with 1 wired to the mid and 1 wired to the woofer on the crossover. Or, do I order a random 5-6" woofer which won't match my mains (as I don't have room for an 8" woofer in my center channel), but will likely deliver better mid/midbass response?
Also, is using real hardwood ok?
Thanks for any help!
Harman Kardon Sig. 2.1 (100x5)
Denon AVR 1907
JBL LX 44's
TSI series Center and Surrounds
Klipsch Synergy 12 sub
Disapproving Wife
LG 46" LCD
PS3
DirecTv
Comfy-**** couch
Denon AVR 1907
JBL LX 44's
Disapproving Wife
LG 46" LCD
PS3
DirecTv
Comfy-**** couch
I think the best way to do it would be to look for something smaller in that series in a two way design. If you use dual midwoofer/mids you will have to watch impedance. If they are both 8 ohms and you wire them in series the impedance will double, as will the crossover frequency if it was for an 8 ohm load. If you wire them in parallel those figures would be cut in half. Or you could do what I plan on doing and building a TV stand with a built in full range center channel. I would use 4 midwoofers and an sl2000 and a passive radiator. I also plan on building a sub using a couple passives and 4 8" drivers. Who knows I might even merge them into one enclosure for the TV stand. By using 4 mids I can wire them into a series/parallel configuration to end up with the load I need. Using 4 8 ohm drivers I can wire them to get a 2, 8 or a 32 ohm load by wiring them in parallel, series/parallel or in series respectively.
BigBankBii,
I'm interested in doing the same thing. Building a center to match my RTA RT11s. Let me know what you end up doing here. Thanks!!
-marcc78735
