How much power is enough?
BigBankBii
BigBankBii Posts: 19
edited January 2012 in Speakers
So I recently revived my old Harman Kardon Sig 2.1 amp. Mid-quality Denon AVR as pre-amp. HK is 100x5 @ 8ohms.
I'm considering a pair of Rti A7's, but keep seeing reviews about a need for real power in order to properly enjoy these. Is HK's 100 watts per good enough?
Perhaps I bi-amp the mains and run the surrounds off the Denon?
Thanks for any help...
Harman Kardon Sig. 2.1 (100x5)
Denon AVR 1907
JBL LX 44's
TSI series Center and Surrounds
Klipsch Synergy 12 sub
Disapproving Wife
LG 46" LCD
PS3
DirecTv
Comfy-**** couch
Post edited by BigBankBii on
  • PrazVT
    PrazVT Posts: 1,606
    edited January 2012
    I'm looking at the manual - and the important stuff is here:
    5 x 100w all channels driven 20Hz - 20KHz @ 8ohms
    Current Capacity: 100A
    The wattage is a little lower, but it's very high current - I think the A7s will perform well with that amp - and definitely much better than off of the Denon. You should be able to hear an improvement - experiment!
    If Denon bi-amp functions applies to the pre-outs as well (or you get 2 RCA Y-adapters and connect them to the front left/right pre-outs), it's not a bad idea to try passive bi-amping for the mains and then run surrounds off of the receiver - see how you like it. Just my 2 cents.
    ALL BOXED UP for a while until I save up for a new place :(
    Home Theater:
    KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
    2 Channel:
    Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs
  • SRTer
    SRTer Posts: 372
    edited January 2012
    BigBankBii wrote: »
    You should be fine. It really will depend on how much volume your trying to make and how much room your trying to fill. I think if you had closer to 150 watt or better, you would have all that you really need.
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
    Receiver: Pioneer Elite SC-35 (140 watts x 7)
    Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
    Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
    TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
    Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks
  • BigBankBii
    edited January 2012
    Cool thanks!
    Yeah, I was thinking about the Y adapter method. But would my mains then overpower the center channel?
    Denon AVR 1907
    JBL LX 44's
    Disapproving Wife
    LG 46" LCD
    PS3
    DirecTv
    Comfy-**** couch
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2012
    Just go into the system and recalibrate all speakers again.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited January 2012
    How does it sound thus far, on selections you are familiar with? The HK will do the job, but you can reap the benefits of seperate amps also.
    Cheers,
    Russ
  • BigBankBii
    edited January 2012
    My JBL's are too harsh for HT use and a bad match for the Polk center. Hence, I'm looking for better/matching mains. Just wanna make sure I've got enough power...
    Denon AVR 1907
    JBL LX 44's
    Disapproving Wife
    LG 46" LCD
    PS3
    DirecTv
    Comfy-**** couch
    tonyb Posts: 33,011
    edited January 2012
    Your fine, don't sweat it.
  • jbooker82
    jbooker82 Posts: 1,627
    edited January 2012
    My RTi A7 hit 106db with about 60 watts from my Carver amplifier. That is with my onkyo at reference.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • blueboxer
    blueboxer Posts: 621
    edited January 2012
    In my SBC it was about 550. :)
  • djperez81
    djperez81 Posts: 388
    edited January 2012
    BigBankBii wrote: »
    Cool thanks!
    Ya they might overpower and you want your front stage to blend. I think the HK would give you cleaner power than your denon. But see what sounds good to you. Like praz said the HK is high current and is 100wpc all channels driven vs your denon which isn't. Play around with your setupband see what sounds good to you. An SPL meter would really help you out if you are worried about your center being overpowered.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • BigBankBii
    edited January 2012
    Oh yeah! Make no mistake, Tge HK is fully hooked up. My first separate and the upgrade is amazing.
    In light of this thread (and playing around), I raised my Denon xover and my sub to 120, and the mids and highs had an immediate and dramatic improvement. And equally suprising, my Klipsch sub sounds pretty good in blend. Gonna try this for a while and see how well rounded it remains in HT. That HK is a fine amp!
    Denon AVR 1907
    JBL LX 44's
    Disapproving Wife
    LG 46" LCD
    PS3
    DirecTv
    Comfy-**** couch
    tonyb Posts: 33,011
    edited January 2012
    Are you using both crossovers....receiver and the subs ? Should only use one bro, turn that one on the sub all the way up to it's highest value.
  • djperez81
    edited January 2012
    What sub you running?
    -Jimi Hendrix
  • BigBankBii
    edited January 2012
    It's at it's highest, which is about 125hz. Pre is set to 120hz. I really only even tried this because I'm considering adding some smaller monitors for my HT setup, which would require the sub to be up that high. Had low expectations for the Klipsch Synergy 12, but it sounds pretty good.
    Denon AVR 1907
    JBL LX 44's
    Disapproving Wife
    LG 46" LCD
    PS3
    DirecTv
    Comfy-**** couch
