SL2000 replacement
PryingEars
PryingEars Posts: 5
edited February 2012 in Vintage Speakers
My 30 year old Monitor 10s are in need of a tweeter in one of the enclosures. I think it has the SL2000 tweeter in it now.(1). Can I get a replacement speaker and (2). should I replace tweeters in each enclosure? (3). If available, where can it (they) be purchased? Thanks a million for any help.
Post edited by PryingEars on
  • onebadchad
    onebadchad Posts: 364
    edited January 2012
    3 on ebay right now
    Hello Kitty am/fm CD player
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited January 2012
    PryingEars wrote: »
    The SL2000 tweeter replacement would be the RD0-194. YES you should replace them because the replacement tweeter is BETTER. You would need to replace both tweeters. You can purchase them by calling polk.
    F1nut Posts: 50,757
    edited January 2012
    Get the RD0194-1 replacement tweeters from Polk for both speakers. Your PryingEars will thank you.
  • helipilotdoug
    helipilotdoug Posts: 1,229
    edited January 2012
    +1 The RDO-194 tweeter is far superior to the old SL2000. Call Polk audio to order, and don't forget to tell them you are a Club Polk member. It'll save you some $ You should order replacement RDO-194 tweeters for both speakers.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • PryingEars
    PryingEars Posts: 5
    edited January 2012
    Thanks to all for your help from this newbie. (What a terrible word...hurts my ears to even say it)
  • PryingEars
    PryingEars Posts: 5
    Just ordered a pair of RD0194's as replacements for my cracked SL2000's. Anyone know if they are "plugNplay" or will I have to solder them in? Thanks.
  • inspiredsports
    inspiredsports Posts: 5,501
    PryingEars wrote: »
    Good decision. Yes, they are "drop in" and "plug and play".
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
