Speakers/Sub placement
Hi Guys:
I am putting together HT. Could you please advise me with proper speakers placement? I like the sound but wondering if it can be improved. system:
F: RTiA7
C: CsiA6
S: FxiA4
Yamaha a2000 + Emotiva XPA-5
Sub: DSW 660Pro
F: RTiA7
C: CsiA6
S: FxiA4
Sub: DSW 660Pro
Post edited by Hannzz on
Not really something that can really be done visually, but perhaps a few general suggestions might nudge you in the right direction.
Subs tend to work better in corners, and they also tend to work better nearer to the listener, if that is possible. About the worst possible place for a sub is out in the middle of the room. The R/L speakers however should not be in corners. Might try moving them (the right one anyway) farther away from the side walls. Toeing them in creates a smaller sweet spot than having them firing directly forward, but whether or not that is something that should be changed depends on the size of your listening area and the distance from the speakers.
