Def. Tech Sub. Compatability
mara5
I have an older DT sub: Powerfield 15", that is about 21 yrs. old. Great shape, as that it was only used for about 6mo. total.
How well would it blend in with KEF xq40's,Harman Kardon 990, room app. 14X14?
Post edited by mara5 on
I would just try it out and see if it works well. It may just do fine.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Make sure it is calibrated properly before you render your final verdict. Once I calibrated my system it made a world of difference (especially in blending the sub).Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
+1
I would recommend calibrating the sub lower than the mains, i.e. if your test tones register 75dB for the front L/R channels, set the sub to 72-73dB for a nice blend. The RadioShack SPL Meter is not as sensitive in the lower region, so actually setting the sub lower equals a flat response.polkaudio RT35 Bookshelves
