What are these?
zingo
They look like they could be a Speakerlab design with the vertical mid horn, but I'm unsure. I feel like I've seen them somewhere in the past, but maybe someone here would know. I don't think they are custom, but anything is possible...
Post edited by zingo on
Not sure what they are. Mr. Hardy will know! They sure look interesting. Did you snag them? How do they sound?--Gary--
Have not snagged them yet as they aren't cheap. These would replace my custom Klipsch Fortes if I pulled the trigger, but I just don't think it would be a step up...
They look very much like a speakerlab design. I remember hearing Speakerlab 7's with a vertical horn. The dispersion patter was much smoother than normal horizontal horns for nearfield but lost something once you stepped back a bit.
They remind me of: http://www.stereophile.com/floorloudspeakers/jbl_synthesis_1400_array_bg_loudspeaker/index.html
Any way you can demo them first? For all you know they could be a DIY job. Which may, or may not be a good thing.
