New MIT cable burn in
acmf74
I just received a pair of MIT CVT-2 IC's yesterday. While I was reading the instructions, it mentioned that
"If burning in interconnects only, your amplifier does not have to be turned on, just source components."
Essentially can I just hook them up an old CD player and just play music though it without going to my preamp?
and is this method recomended?
Thanks,
Thanks,
I ran my cd player on a loop and kept my SS pre on as well.just no amp
i wouldnt recommend with a tube preMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Thanks,
You want to properly connect BOTH ends of the interconnects, turn on the source components, and generate a musical signal (play a CD, tune to an active FM station, etc.).
You don't need to turn the amplifier on unless you are burning in speaker interface cables also.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
My question belongs in the electronic forum but didn't want to start a new thread. Would running my Jolida CDP on a loop all weekend damage the tubes?
Nope.Political Correctness'.........defined
President of Club Polk -
fashion master wrote: »If your ground is bad or you have a short somewhere else, you could have the problem of your current not having a place to go. When your current backs up you could fry a wire. Also, whatever machine you are using, if it uses a voltage regulator/recitifier or anything like that, a faulty one could fry a wire. That was the case with my motorcycle. Bad regulator fried a wire.
I've read all 5 of your contributions to the forum so far and none make sense. They read like something you excerpted from Wikipedia.
Something's up. Reported as spamVTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels
